Question about Cuisinart DGB-600 Coffee Maker
Continue to get beeping after taking out basket, emptying water, re-inserting basket and making certain lid is clicked shut. Thoughts?
  • 3 Answers
All the parts have to be in place, including both the removable grinder unit and its clear cover, even if you're using pre-ground coffee.
It also requires that both the top lid and the front "door" (to the basket area) are clicked shut, and that the basket and its cover are both in place.
One thing to check carefully is the clear cover to the grinder unit. There's a rubber-like "nub" that seems to actually control the switch, which tells the machine that the grinder unit is properly installed. If that rubber-like nub is missing (and unfortunately it IS possible to remove it, particularly during cleaning) ... that could be causing your problem. If you see a hole in the top of that clear cover... you're missing that "nub".
Posted on Oct 14, 2010
  • 3 Answers
MAtechie has it almost correct. The silicone nub he refers to is nothing more than a vibration damper on the grinder cover. On the side of the grinder cover there is a white plastic pin, it may rattle a bit when you have the cover off of the grinder. The white pin in the grinder cover acts as a "go between" or extension between a molded post on the cover of the unit, and a contact switch in the unit.
Posted on Aug 06, 2012
My basket always overflows, the water doesn,t empty fast enough
Here is the SOLUTION(S):
1. Buy a sprayhead that restricts the flow2. Let the water flow through for a few minutes, then lift the lid while it flows through.3. Don't use Decaf4. Plug up a couple holes on your current spray head
Mar 24, 2012 | Bunn BT10B Coffee Maker
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
    First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
    - Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
    - Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
    - Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
    - Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
    - The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
    - Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
    - If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
    - Check the Tank Lid and Tank for damage.
    Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Basket doesn't spin when emptying wash water
    remove door switch and tape the wires together, if it works fine now. replace door switch!
    Jan 11, 2010 | Kenmore Washing Machines
    The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
    Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
    FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
    You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
    Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
    I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
    Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
    If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
    Waiting for your reply….Rich
    Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
    How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
    From the manual I found online here.
    CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
    DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
    Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    Cuisinart Grind and Brew will not emply all the water
    The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
    Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    I just purchased a dgb 550 series 2 days ago, I was moving it and it is now making a beeping sound and will not allow me to do anything, I have unplugged it and replugged and it still does this I tried to...
    The constant beeping means that something is out of place - make sure the charcoal water filter holder is in place, even if there are no filters inside. Make sure the grind chamber and all parts are in place. Make sure the filter basket is in place, and that the door is closed. Finally, make sure the lid of the coffee maker tiself is shut and that the lid of the craffe is firmly in place. If everything is in place, it should stop beeping. Turn the coffeemaker off, and then on after all of this is done.
    Mar 08, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
    Manual
    Here are the instructions that came with the cooker:
    Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
    To Cook Rice:
    1. Remove basket.
    2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
    3. Transfer the rinsed rice from the basket to the bottom of the cooker.
    4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
    5. Secure lid and lock clamps. Open vent holes.
    6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
    7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
    8. Remove rice from the cooker and fluff with a fork.
    Yields: 3 cups of cooked rice or 4 to 6 servings.
    Cooking Potatoes and Vegetables:
    1. Insert Basket.
    2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
    3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
    4. Secure lid and lock clamps. Close vent holes.
    5. Microwave on high for 3-4 minutes.
    6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
    Cooking Pasta:
    1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
    2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
    3. Add 2 1/2 cups water.
    4. Microwave on high setting 10 minutes, stirring after 5 minutes.
    5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
    Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
    Cuisinart DGB-600 Coffee Maker Logo
    396 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    880runner
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
