Question about Bosch Refrigerators
The alarm on my fridge freezer keeps being activated when I am out of the house, neither of the doors has been left open so i think it must be a temperature thing. However, when I adjust the temperature it still keeps beeping and only responds when I silence the alarm. What is it trying to warn me about?
  • sellokel May 16, 2008
    Thanks a lot. Away for the w,end. Will try next week & let you know
  • 828 Answers
It may be warning you that maintenance is in need. Check and clean your condenser coils . Under in front behind toe plate or in back behind removable fiber panel. Make sure the panel is replaced after you clean the condenser.
Posted on May 15, 2008
Refrigerator alarm when you open the door
It sounds like some kind of child alarm has been activated. what model of fridge is it.
Feb 23, 2016 | Refrigerators
Alarm does not come on when the fridge door is left open on frigde freezer
Alarm probably frozen, leave door open to let heat in to melt ice, the remove device.
Dec 14, 2014 | Zanussi Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
I came home from work and my alarm was on. The temperature on both the refrigerator side and freezer side was going up. The food in the freezer is thawing and the refrigerator is barely cool. I thought...
Let it unplug for an hour and set temp to your preferred setting and then plug in again. This will resume to normal operation.
Be sure that electricity in your home is not fluctuating or surging as it will cause false alarm or your fridge. It can intermittently operate your fridge.
Thanks for asking
Jun 24, 2011 | Kenmore 76582 / 76584 / 76589 Side by Side...
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Whirlpool fridge alarm sounds when opening the door most times.
Speedysgarag, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Speedysgarag), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool ARC4030 Stainless Steel Top...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
989 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
