Question about Philips DECT VOIP-321 cordless telephone
Base not found - Philips DECT VOIP-321 cordless telephone
Ihave a 31" polaroid tv (measured corner to corner) and need a new base but don't have the product number as thrown packaging away. Where can i find a base?
Please mention what kind of base you are talking about, wall hanger or flat floor base?
Furthermore, as you mentioned you dont know the model number, I would prefer to measure the base screw holes (on your TV) and make / design your own custom made base for your TV.
Or measure the hole-to-hole dimension (on your TV) and go some nearest Shopping mall, you can found a separate base (but before going to purchase make sure its matching your TV as you measured), which you can found easily, and buy one.
Oct 03, 2015 | Polaroid Televison & Video
Converting binary to decimal
Please see the screen captures below.
To set the base in Main.
To convert from one numeration base to another, use the baseConvert( command found in the catalog (cat)
baseConvert(number to convert, current base, expected base).
The number to convert must be positive integer (digits 0 to 9 and/or A to F). The current base and expected base can be any positive integer between 2 and 16
May 04, 2014 | Casio ClassPad 300 Calculator
No data base found on device
Hi it's look like your GPS is wiped. Connect your GPS to pc and go to your manufacture website, download software for it and purchase map to make it working.
Apr 08, 2014 | GPS
Log 3 base 10
Press LOG 3 ENTER.
The LOG key on the keyboard gives you base-10 (common) logs while the LN key gives you base-e (natural) logs. If you want the log to another base you can use the logBASE function found in the catalog.
Apr 07, 2014 | Texas Instruments TI-84 Plus Calculator
Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Mar 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Philips CD6451B/37 Cordless phone w/Answering machine-NO BASE FOUND-SEARCHING
Try changing the battery. Try using a new AAA rechargeable battries.
Oct 23, 2008 | Philips CD6451B/05 Phone
SONY NW-HD MP3 PLAYER
I TRY TO PLAY MUSIC AND IT SAYS NO DATA BASE FOUND
Oct 11, 2008 | Sony NW-HD5 MP3 Player
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Philips DECT VOIP-321 cordless telephone Logo
133 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
