Question about Singer 3116 Simple
My top thread wont raise the bobbin thread. It just keeps getting jammed in the turning contraption were the bobbin is housed.
    Genius:
  • 1,788 Answers
Try metal SA 156 bobbins, they seem to work better. You can buy them on ebay 20 for $8.99 and free shipping.
Posted on Sep 14, 2010
I have a Kenmore 385 19153 the thread is breaking any keeps jamming in the bobbin
Could be threaded incorrectly. Remove the thread from the machine. Put in a brand new needle.. ALWAYS RAISE the presser foot and rethread the top thread from the beginning. (AVOID old or bargain bin thread--might even try a different type of thread.) Check that the thread path is correct. Then put bobbin in the bobbin case and thread it through the tension. Check that the bobbin is turning the correct direction in the bobbin case. Install the bobbin case in the machine. Start out with the top tension set about the midway point and then tweak it from there to get the appropriate tension.
Pull the bobbin thread to the top of the fabric and gently hold both thread tails in your left hand while you slowly take the first few stitches.
If you continue to have issues, then you may need to have your machine serviced. It could be out of time or perhaps there is a snag or burr that is catching the thread.
Nov 13, 2017 | Kenmore Sewing Machines
Thread suddenly jams , bobbin won't turn,after cleaning, re-threading etc makes one stitch with wheel turn then jams again.
Besides installing a brand new needle (which you've already done), unthread the top thread. (Cut the thread below the spool, raise the presser foot, and pull the thread DOWN from the thread tail end--NEVER PULL thread UP!)
ALWAYS RAISE the presser foot and rethread the top thread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point and then tweak it so both threads meet in the middle of the fabric.
Jun 24, 2017 | Sewing Machines
I have a deco 600....it keeps on jamming. The top thread gets entangled with bobbin and the machine jams fast and the needle breaks.
try adjusting the needle thread right up to stop the bunching of thread that is causing the problem
Oct 16, 2016 | Sewing Machines
What to do to fix the bobbin thread from jamming up everytime
There are a couple of reasons that can cause this.
a. Raise the pressure foot. As you load the top thread give small tugs to check for snags. They must be stopped.
b. Once the top threading is done on top lower the pressure foot. Now, give a tug on the thread. Is the tension really hard or just average? You may need to lower the tension to stop the jamming of the bobbin thread.
c. Clean the bobbin area. Check the bobbin tension and adjust as you need to.
d. Put a drop of oil on the race. (Thing the bobbin case sits on)
e. As the bobbin hook (sharp thing) is rotating does the bobbin case move back and forth a lot. You may need to adjust the bar that is next to the bobbin case so it can't rotate. Usually you will need to move it forward.
SEE INSTRUCTIONS HOW TO ADJUST THE BOBBIN. TENSION OF UPPER AND LOWER THREAD MUST BE RIGHT.
Nov 28, 2015 | Sewing Machines
I have a circa 1962 Elna and the thread keeps tangling under the pressure foot by the bobbin. I have rethreaded it twice as per instructions in the owners manual and still is happening, any suggestions?
if you are getting loops on the underside of the fabric or jamming around the bobbin, then your top thread is not under tension or going through the thread take up lever, that little arm that moves up and down. Recheck your threading path making sure you always raise the presser foot to open up the tension discs so that the thread lies into the tension discs fully. Also check that you have the bobbin threaded up correctly into the bobbin case, with the thread caught into the tension spring (you will hear a little click as it goes in). The bobbin will turn anticlockwise as you draw thread out of it. Use the top thread to raise the bottom thread up, replace the needle plate and bobbin case cover in place, then take both threads to the back of the sewing area. Hold them firmly as you start sewing! very important that you don't allow the thread tails to be caught and dragged into the bobbin as they will jam around the rotary hook.
May 05, 2014 | Elna Sewing Machines
Pfaff quilt expression 4 0
Not sure what the problem is but you might try this:
Remove the top thread completely from the machine.
Make sure the machine is cleaned under the needle plate, the hook/bobbin area, the feed dogs, etc.
If your manual instructs oiling, do so as described.
Confirm that the feed dogs are in the raised position.
ALWAYS RAISE the presser foot then rethread the top thread from the beginning.
Confirm the needle is installed correctly (does the flat part face the right direction?). Is it the right needle for your machine.
Set the top tension to the midway point.
Check that the stitch length is set to at least #2.
Re-test your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
Some machines have a presser foot pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and the feed dogs. You may need to increase this pressure.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjUwYDwuKjVAhULwFQKHRLIA1YQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AFQjCNFFR0YpgCUh8R92wNbPzlJpuzWVNw
Jul 26, 2017 | Sewing Machines
Jamming
try changing the needle
rethread the machine top and bobbin
even try a different bobbin--make sure the bobbin is turned the right
way
make sure the top thread has not come off the thread take up lever
Dec 22, 2012 | Sewing Machines
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
Prolectrix 8 stitch sewing machine top thread keeps getting caught round bobbin housing and jamming everytime i try to use it
Sounds like the take-up lever is not threaded.
Remove the thread from the machine, turn the handwheel until the take-up lever is at its highest position, raise the presser foot and rethread the machine. Set the upper tension dial to 5 and retry.
Aug 18, 2009 | Sewing Machines
Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Feb 20, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 3116 Simple Logo
62 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
