Question about Genie Company IntelliCode GICT390-1BL Remote Control
Garage door light will not turn on automatically when door is opened. Tried 't several new lights but that didn't work. Any ideas on troubleshooting?
    Scholar:
  • 143 Answers
This is either a light socket problem or a logic board issue. Unplug the unit and open the light cover. In the bottom of the socket there is a copper lead. Pull this up with needle nose plyers as the bulbs may not be making contact with the lead. Then try it out. If it does nothing either your socket is bad or the logic board is bad. You can test the socket with a circuit tester. If it is bad replace it, if it is good replace the logic board. You can get replacement parts at genie.com or overheaddoor.com. Thanks BB
Posted on Oct 10, 2010
Aparker@primelending.comRe. the security+ light feature on LiftMaster #1265......it is no longer working. Light can be turned on, and comes on when door operated, but will not come on when beam is broken....
Try these instructions in case they are different from what you have.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Jul 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
I have a Craftsman 139.18856 Garage Door Opener. Recently i found that both bulbs (1 connected to the front of the motor and 1 on the ceiling above) were fused so i changed them. They dont seem to go off...
There are a couple different light features depending on the model opener. There is one where you can change the duration the light stays on and another model has a motion detector that turns the light on. Another has a feature where if you walk in through an open garage door it automatically turns the light on. Your model number is recognized by Sears so I can't really tell what you have. Double check the model number.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a pair of Chamberlain Liftmaster Professional openers (Chamerlain Model 2500 belt drive) in my two-car garage. Both systems are identical, so it is easy to troubleshoot. I am able to completely...
It sure sounds like you have a light bulb that is generating a radio signal that interferes with the receiver in that one opener. Remove the bulbs and try. As strange as it sounds it can happen.
Nov 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears garage door opener. The motion
The light will stay on as long as you are in the garage and it detects body heat. If you leave the garage the light should turn off.
Aug 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light will not come on when you walk into the
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
My light on my craftsman garage door opener won't turn on
Unplug the unit from the power and take a small screwdriver and lift the center contact in the light sockets just a bit. This usually fixes the problem if you haven't had electrical surges or lightning.
May 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Main light on will not come on when door is opened/closed
For some reason, the bulbs I tested that worked somehow didn't work correctly when inserted into the door opener. We opened another set of bulbs we purchased and what do you know, the light now works. I don't fully understand as the other bulbs did work just not in the garage door opener.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener
From the manual:
Security+Light Feature: Lights will also turn on when someone walks through the open garage door. With a Premium Control Console, this feature may be turned off as follows: With the opener lights off, press and hold the light button for 10 seconds, until the light goes on and off again. To restore this feature, start with the opener lights on, then press and hold the light button for 10 seconds until the light goes off, then on again.
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Genie Company IntelliCode GICT390-1BL Remote Control Logo
357 people viewed this question
Top Genie Company Televison & Video Experts
Dan Apthorp
Leonard Manamela
Leonard Manamela
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
