Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Hello. I am trying to get my NAT open with my linksys BEFSR41 V4.3
  • 550 Answers
You are trying to open the NAT on the router.
For this you will need to reduce the MTU settings on the router
to 1365. Disable the UPnP on the router.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Posted on Sep 14, 2010
I have a linksys befsr41 but I do not have the installation cd and I am using OSX 10.6.4. Please help! Merci beaucoup
When you connect your router using an Ethernet port you don't need any driver.
To access the configuration and setup of your router open your internet browser and in the address bar enter 192.168.1.1 and then press enter.
By default user is blank and password is admin
Here the manual and installation guide for your reference
http://www.linksysbycisco.com/UK/en/products/BEFSR41?lid=LearnMore
regards
Jan 31, 2011 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have 2 xboxs and each work fine on the slow speed enternet alone i upgraded 8 times faster to put both on at same time now i have more lag and enteruptions then ever my xbox tells me to open my nat and...
It seems that there is an issue with traffic congestion here. Try connecting at different times of the day to see if that helps. Also it wouldn't hurt to upgrade your internet package if you can afford it.
About the NAT: The Xbox should run just fine without NAT being open, but it wouldn't hurt to open them.
Depending on the router there are different ways of setting it up, but if you have default settings, you should be able to go into the router and change some settings to make it run more efficiently.
Basing off that router that you suggested the issue is with, Assuming you have default settings, go to 192.168.1.1 on a computer connected through the router (Through one of the ethernet ports) and login with either "1234" as the username and "admin" as the password (no quotes) or a blank username and password "admin"
Then follow these steps on this website, but do not change port 80. http://portforward.com/english/routers/port_forwarding/Linksys/BEFDSR41W/Xbox_Live_360.htm
Jan 17, 2011 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Strict NAT on my Xbox 360
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
Make sure that the UPnP is enabled on the router.
May 07, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do i change my nat type from strict to open on a linksys befsr41 router i've tried all the solutions xbox live and bungie has told me to try except for buying a different router or changing service...
Under applications and gaming, you will want to select upnp forwarding and then you can enter whatever custom application you want to be allowed in or out.Upnp can also be set automatically from the Administration menu.
You will need to know which ports to use, usually you can get these from the software developer, such as bungie. You can also use the application name, but I find the numbers easier to work with.
Jun 29, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Opening Port 123 on my Linksys BEFSR41 Router
Hi:
It turns out I didn't need to open port 123 on my router to get SymmTime to work.
Thanks for the efforts
Brad McMillan
Dec 16, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do I turn NAT from strict to open on a 2.4GHz router
sir try to view your router using the web base configuration, locate the NAT configuration and enable DMZ function. it should open all ports with your xbox
Sep 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
OPENING NAT FROM STRICT TO OPEN
Sory to say this .....1 find a tech who knows networking... or.. call Linkys support to help with reset/setup...My final solution.... buy a different router... I've had trouble With Linksys before.
Mar 15, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
NAT
First, you need to get into the user interface for the router.  To do that, just open your web browser, type in 198.168.1.1 & hit enter.  A login prompt will pop up if you're able to access the router.
If you've never done this before, the username is blank & the password is admin
What, exactly do you want to do with the NAT firewall?
To enable/disable NAT: click on setup, then click on advanced routing.
To filter Internet NAT redirection: click on security, then click on filters.
You can find this information in the User guide provided by LinkSys at:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859876500&displaypage=download
Select your version number, then click on User Guide when it comes up.  User guides & Interfaces for the BEFSR41 are almost identical on every version.
Oct 27, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
