Question about Briggs & Stratton Garden
Troy Bilt 4.5 HP, 2.2 \r\nUsed to be a steady idle.....now it putters and on and off. Pressure is about the same as always, but then it goes steady idle for about last 15 seconds before it runs out of fuel. I changed from regular unleaded to premium...and still the same. I have not looked into the wand or o-rings at that end. I just want it smooth and not erraticly noisy..like it struggling for dear life. :o)
  • Brad Brown Jul 24, 2017
    Hi wmrios, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is this on a pressure washer? If it is can you advise any other info on machine model number or engine model number?
  • 4090 Answers
SOURCE: pressure washer not working
sketchy info here....
Remove the hose and gun to see if water is flowing....
if it is that means there is no blockage in the hose or gun. When its connected if it runs at the same rate as without the hose and you have set it into pressure clean mode, then the pressure valve and seal have collapsed. Estimated repair cost is $200 and about $100 of that is labor. It is not a DIY unless you know your way around and have the right tools. Having it repaired professionally gives you 3 months warranty as well. Do it yourself and you could end up losing some of the small screws and other nylon components that tend to drop out and get lost when you open it up!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 13, 2009
Testimonial: "Very quick reply,very informative,very helpful. Thank you."
  • 174 Answers
SOURCE: Soap will not siphon on my Troy Bilt pressure
Are you using the soap on low pressure. This is the only way it will work
Posted on Sep 20, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How can I get my snow blower to idle in a steady fashion?
Tune up and carb adjustment. There are two screws on your carb which control the low end(idle) and the high end (throwing power) Play with those with very small turns to adjust.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy-bilt TB525ET 4 cycle??
no you do not mix gas but there is a type of oil that goes in the back of your engine called the houle and im not sure if its 4 meaning regular oil or 2cycle im thinking its 2 because as the engine runs it mixes on its own to create a so called 4 cycle which to everone ive talked to on the outside is a week engine im being told that 2cycle engine has alot more tourque if you want to get a job done quick and it look good
Feb 21, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What kind of oil goes in crankcase
Rule of thumb for lawn and garden equipment ...
If it is 2 cycle - gas and oil are mixed - 50 to 1 mix. Some two cycle engines require more oil ... up to 32 to one.
It if is 4 cycle - has a fuel tank and a crank case - 30 weight oil SJ or better service rating.
If you want to become an expert on oil ... go here: http://www.bsehome.net/pdf/OIL_S_EG.PDF
And a final word ... it is always good to refer to the manufacturer recommendations when selecting lubricants. Troy Bilt (no longer manufactured by the Troy Bilt Company in Troy New York) uses a number of different engines on their procducts. Here is a link for you: http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54971_54970_54970_-1?cm_mmc=Google-_-WG-_-Tillers-_-Sponsored
Thanks for using FixYa.com
Mar 22, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
I have a troy bilt 4 cycle. I have had it for
clean the carburetor. and make sure the screen in the carburetor is clean and clear. your best to take it out and spray a drop of carb clean and burn it off. also make sure the fuel filter is clean to. the diaphrams may be a little stiff so clean them to.
May 02, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Oil for a troy bilt 2550 psi pressure washer pump
May 17, 2009 | Briggs & Stratton Garden
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
55 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
