Question about ViewSonic VX2235WM Monitor
The monitor display"No Signal Digital" when start up, and later the minitor turn black.
  • 11,361 Answers
It may not be getting the signal from your PC, I would try it with another PC first to make sure it is not PC's Video card problem, otherwise it may have problem inside like unsteady DC voltages due to bad caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 14, 2010
My dell vostro 1510 turns on but the screen remains off, completely black. What should I check for a diagnosis?
Always start with checking the connections/cables. If they are secure, verify that the monitor is set to display the correct signal (ie. Analog or Digital by pressing the buttons on the monitor) You should see text on the monitor screen letting you know the display type.
Oct 22, 2013 | Dell Vostro 200 PC Desktop
Desktop has no signal
That means that the input from the monitor has no read able signal
Either the monitor is bad or the onboard or video card
Take the monitor and hook it up to a different PC to see if it works or hook a different monitor into that PC, that will ID which problem you have
Dec 29, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
Dell model No. 1504FP will turn on for 3 sec then off
THE PROBLEM IS THE MONITOR IT SELF.
IT IS TIME TO BUY A NEW MONITOR. I KNOW ALOT OF OF US CANNOT AFFORD A NEW MONITOR EVERY TIME ONE BRAKES, I HAVE FOUND THAT SECOND HAND STORES SALE THERE MINITORS FROM 1-2 DOLLARS PER INCH, I PICKED UP IBM FLAT SCREEN 20" AROUND 20.00 USD. AND IT STILL RUNNING AND I HAVE HAD IT FOR A YEAR OR MORE NOW.
May 12, 2009 | Dell 1503FP 15" LCD Monitor
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
I bought a lg lcd monitor, but when I connected it to my computer I don,t see any screen. If I turn the monitor off and than on, it gives me a message on the screen (digital power saving mode).please help...
Dear,
you please check all the cables of the minitor connected to the cpu or not. It might happen some time when you disconnect your signal cable of the monitor.
thank you
pradeep
you u have problem again then please remind us.
Jun 22, 2008 | Computers & Internet
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VX2235WM Monitor Logo
135 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
