Question about Sport & Outdoor - Others
I'm looking for an owners manual for an Ice Master model 103 power ice auger by Osceola power Equipment, of Osceola Wisconsin.
  • 25 Answers
SOURCE: Ice Dispenser kitchenaid KSRP25FNSS
first make sure that there is not ice clogging the auger. check that connection to the auger motor is secure. If it appears to be fine you will need a volt meter for the following steps. If you are not comfortable using this equipment or do not want to buy one call a repairman. If you choose to continue remove the leads from the auger motor. Configure the meter to read ohms and place the leads across the motor connections. The meter should read some resistance if not the motor is either shorted or a lead has burned completely due to a short. If the motor is fine configure the meter to read volts. Look on the motor and determine if it is AC or DC and configure the meter for this. Connect the voltmeter leads to the motor feed wires and press the ice despense button. If no voltage is observed check the switch for continuity. Replace any faulty parts. If this sounds foreign to you call a repairman.
Posted on Mar 27, 2008
  • 37 Answers
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
Posted on Jan 03, 2009
SOURCE: Ardis Ice Auger
I pick up a power head from the junk yard this past weekend. The unit was made by Feldmann Mfg. and engineering. I believe this is the same company that manufactures Jiffy ice augers. I paid $3 for it. It looks like it is from the 50's or 60's. It was complete except for the auger. The motor was froze from sitting, but after disasembling, cleaning, cutting new gasket, freeing the rings and numerous other problems I got it running. I found augers in the Northern hydraulics catalog in sizes from 3" to 12". They are for earth and the 8" was $139.99. You would need to contact them for the shaft size to see if it will fit in the power head you have.
Posted on Apr 07, 2009
  • 5 Answers
SOURCE: GE PS123 MGNA CC Ice Auger
I just finished replacing the ice auger in my GE HSS25GFPA side-by-side and offer some suggestions/hints.
The auger (WR17X11705) was available locally (Appliance Parts Co., $28.97). This fits many other refrigerators. The replacement took a little under 2 hours. I estimate these hints may cut the time by one-half.
There are only 4 screws in the entire ice drawer assembly. It possibly was not necessary to remove the control rod. The other 3 screws hold the front cover. There are also 2 tabs holding the top of the cover.
The most difficult part of the repair was removal of the plastic assembly housing the crusher blades and the front bearing of the auger. This is held in place by only 2 large square tabs on the sides. There is enough space to get ONE side to release BUT to get both released required careful prying with thin-bladed screwdrivers (and prayer). These "tabs" don't push in, rather the drawer flexes out. Once released, the unit slides up and angles to allow removal of the auger/crusher. Re-assembly could not be easier. Stainless sheet metal screws would probably work if you do break something.
Remove the clear inside cover of the crusher assembly and the "C" clip on the threaded end of the auger shaft to separate the auger from the crusher.
And now for my PRIMARY reason for sharing my experience - the %#$@ plastic nut/bearing is a LEFT-HAND THREAD. I only realized this when trying to bend my make-shift split screwdrive back and the SOB loosened right up!
Carefully note the locations and orientations of the blades and spacers as you move them from the old to the new auger.
Posted on May 01, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
What direction should ice auger run mine runs counter clock wise
Most ICE augers rotate counter clockwise. There are a few that don't but they tend to based on EARTH drilling augers which generally rotate Clockwise.
Jan 16, 2018 | Refrigerators
Do you have a manual for an osceola power equipment Magnum iii plus 49cc ice auger
Osceola is now Strikemaster (Rapala); I think that model uses a Tecumseh power plant, so the linked manual should get you pretty close. If you need more specifics about the engine, see if you can find a model number on a label or spec number stamped directly on the engine (e.g., TC300-xxxxx xxxxx). https://www.rapala.com/on/demandware.static/-/Sites-rapala-Library/default/dw48864169/downloads/strikemaster/2hp_operator_manual.pdf
Oct 20, 2017 | Fishing
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
ICE MAKER DONT DISPENSE ICE IT MAKES IT IT DISPENSES WATER WHATS WRONG THANKS Model: KSSC48QMS01
Hi and welcome to FixYa, I am Kelly.
Here is a manual that will assist you in troubleshooting:
KSSC48Q
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/507220676c24d02d85256b5800675172/$FILE/4317326A.pdf
I suspect you either have a problem with the switch for the ice in door actuator or the auger motor.
Access to the switch is on page 49 and 50 of the manual.
Ice maker auger motor access is on page 42 and 43 of the manual.
Crush/cube solenoid testing AND the auger motor testing are on page 60.
The schematic is on page 68 of the manual. The basic circuit is power from the disperser lock switch to the Ice lever switch to the motor. If the auger motor has the proper resistance then the Ice Lever Switch is the most probable failure. Listen for a CLICK as you depress and let go of the Ice Lever switch. No click = bad ice lever switch.
The micro-switches in the dispenser panel should be the same part number. The parts break down does a lousy job of identifying the exact switch. However, it should be the same part number as item 16 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132417&diagram_id=28245505#d28245505
This manual may also be of help:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf I think there are some differences from the manual above so it may or may not be helpful. Take a look. For some reason I am thinking about the switch pack but do not see it on the parts list.
Let me know if you need more assistance. Thanks for choosing FixYa,
Kelly
Jul 23, 2011 | KitchenAid KSSC42FMS Side by Side...
Side by side won't dispense ice.
Take the ice container that has the auger inside it and press the door switch in while you press the dispenser. If the auger motor in the back works empty the ice container and see if there may be frozen ice preventing it from turning. If yes then defrost and dry the container and replace. If this does not solve the problem get me your model number for example 213.256489 for Sears and I will help you track the problem down. Sea Breeze
Jul 23, 2009 | Refrigerators
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
The ice wheel not turning
If your model is the JSD2789GES let me know as I have the service manual 118 pages...Sea Breeze
Jun 21, 2009 | Jenn-Air JSD2789GES Side by Side...
No auger power when ice lever depressed
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE S/S Refrigerator model GSS20IEBWW auger not turning
Take a hair dryer and heat the auger drive gear. These will sometimes get moisture on them and freeze up.
Turn the refrigerator off first. Then remove the ice bin. The "U" shaped drive will be in the back.
After you have heated it thoroughly, try to move the gear manually. Resume power and try it again.
May 19, 2009 | GE Freezers
Ardis Ice Auger
Mar 30, 2009 | Tanaka TIA-350s Post Hole Digger -...
Sport & Outdoor - Others Logo
277 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
