Question about Hitachi 53FDX01B 53" Rear Projection Television
Would the red drive control cause red shadows in the affected areas? do i get to the bulbs through the cardeboard back panel? is the drive adjust in the menu screen or a button or screw on the tv itself? thank you very much for the help it means alot to my family and i.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If 3d ghosting do not try adjust screens, focus, or anything.
Look at attached photos and if they look ANYTHING like your problem I can tell you how to fix it and what is involved.
SD TECH
These are convergence problems--no two sets will look exactly the same but you will know if this is your problem.
Post a comment here and rate this solution as very helpful as I do this here for free.
Posted on Sep 14, 2010
Picture bleeding red
My advice to you is to leave it as it is if it's bearable.
if not I'd go with marking the pots on the Y-Main board (the one on the left side of the TV when looking from the back) with a Sharpe, then trying to adjust them one by one to see which ones affects the sparking most.
You may end up having to replace the board eventually, but you should know that it is not guaranteed that this is where the problem is although it is the usual first choice.
www.coppelltvrepair.com
Aug 26, 2012 | Samsung PN50C7000 50" 1080p 3D Ready...
I just got a old fashon 52" Bigscreen TV "PHILLIPS" and it has a red tint to it how do i get it off.?
Answer 1: Adjust the tint control towards the green. If that doesn't work, set it to the center then...
Answer 2: Find the red drive control and turn it down. We can't tell you how to do that without the model number. Look at a white area of the picture and adjust it so it is white.
If all is well, that is all you need to do. However, there are a number of failure modes that could cause this symptom; most of them would be on the red CRT driver board.
Oct 13, 2010 | Televison & Video
We got a free hitachi projection tv that i believe has a bulb malfunction. on the left half of the screen has a red shadow we cant afford a hundred dollars for an estimate then whatever the price of the...
You might need to adjust the red screen drive control, turn the Red down and see if that clears it out. Sounds like the Red Tube is over driving the Green and blue Tube.
Find the Focus and screen control block there will be 3 controls on Top 3 right under them R-G-B they adjust the Focus to each tube and screen drive for each tube. also you need to clean the lenses off top of each tube they get dirty and dusty and it would help to clean the mirror
Sep 13, 2010 | Hitachi 53FDX01B 53" Rear Projection...
50HP66 50 in. Plasma Television: i have red dots/shadowing on my tv...
I got the red dots really bad on my toshiba 50hp66 after an hour or two of watching tv. I found out that if you open up the tv in the back on the left you will find two adjustment pots labelled Vsc and Vy. I took a sharpie and marked where the factory defaults were first. Then I adjusted the Vy pot down a little bit and the red spots were gone! My tv looks great again!
May 16, 2010 | Toshiba 50HP66 50 in. Plasma Television
Symphonic 32'' lcd tv has shadow on right side of screen
The "shadow" indicates a failure either of the LCD controller, LCD connector, or in the worst case, the LCD itself. A loose connection between the LCD and the LCD controller can result in abnormal displays. Try tapping the back of the TV and check if the shadow can be affected. If it is affected, try cleaning the connector terminals with a soft-bristle brush and alcohol or lacquer thinner. If not, have it checked by a qualified technician to carry out the proper tests to determine which of the LCD controller or LCD the problem lies.
Dec 06, 2009 | Televison & Video
Red static/shadowing in black areas. I have read something about it being LCDS cable???? where do i get a new one?? John
It's called Red Solarization. It could be the LVDS cable..or the panel control board...or the panel itself..some control boards only come with panel..unless you've changed a panel before I would advise you to take to a repair shop.
May 06, 2009 | Televison & Video
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Red color halo/shadowing
can you post a pic of your screen to show the shadowing, as red usually isnt affected with coolant contamination it may be a convergence issue. A pic would help me be better able to help diagnose the problem.
May 02, 2008 | Sony KP-53HS30 53" Rear Projection...
Green and red shadows
try adjusting the color purity knob.one by one,or if it is really bad tube u can extend it by rejuvinating it.
Mar 24, 2007 | Toshiba 43H71 43" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
