Question about Kitchen Ranges
We have a ceramic stovetop and temperature control doesn't seem to work well. The temperature control seems to cycle between very hot and then it goes off. This on/off control makes cooking things difficult. Is her something wrong with the temperature controller or am I doing something wrong?
  • johnmercer Sep 14, 2010
    I don't think there isn't any master temperature controller for the top elements.Isn't the control in each element switch?
The problem is the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. Replace the igniter
Posted on Sep 14, 2010
  • 734 Answers
It can only be the temperature controller (if all the "burners" have the same problem) or if it's just one burner then it's in the contacts inside that knob.
If the appliance is out of warranty, then you might get lucky and find out the problem is ubiquitous for your model and there's a "service enhancement" program for it. Otherwise you'll need an appliance repair service locally.
One thing for sure, the problem is not you. :o)
Kind Regards,
Marcus
Engine temperature gauge low
I would suspect the thermostat first.
Aug 17, 2017 | 2002 Dodge Grand Caravan
Dishwasher runs, but the water doesn't seem to get hot and the dry cycle doesn't seem to be working. I ran a cycle with a bottle of dishwasher cleaner. It has little wax stopper that blocks the...
No there is not a reset button on diswashers. I would suggest you take the heating element out and check it with an ohmmeter to see if that is the problem - which is the most probable cause. If it is open - infinity reading on the ohmmeter, then it is bad.
If it is good then, it would be the control board.
Aug 14, 2011 | Dishwashers
My RS696 was doing a cleaning cycle and displayed and -F3-. Is this a sign that I need a new oven. Stovetop seems to work fine.
Hello & Welcome to FixYa
F3 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 08, 2011 | Ovens
Stovetop heating elements turn off and on intermittently. They don't stay on.
The heating elements on an electric stovetop are controlled be a control called a reohstat. The reohstat regulates the temperature to the elements and as such they do cycle on and off during use. If you turned the control to low and the element stayed on all the time it would get too hot and burn what you're cooking.
Feb 06, 2011 | Kitchen Ranges
I have a kitchenaid ceramic stovetop. recently I used the self cleaning oven and now it seems to not operate correctly. there is a frequent beeping noise....
is it the glasstop range with the oven control panel in the front? if so one of your over temperature thermostats is faulty.. it is probably causing an f-1 error.OR.. your temperature probe in the oven could be going bad.
Jan 01, 2009 | Crosley CE35111AA Electric Kitchen Range
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
Kitchen Ranges Logo
108 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
