Question about Dynex 32 in. LCD Flat-Panel HDTV
I want to connect my tv to the ps3 - Dynex 32 in. LCD Flat-Panel HDTV
  • 616 Answers
Please find a teenager and give him/her $10 to do it.
Posted on Sep 14, 2010
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    What cables do i need to connect my ps3 to my sony recevier.
    do you wan the suround sound to play sound for what the tv is displaying or just the ps3
    for just ps3
    connect hdmi to ps3 and tv
    connect optical to ps3 and suround sound
    change video settings to hdmi
    change sound settings to optical
    it asks to set settings automatically you have tyo doo it manually
    if you want to play every thing that tv displays then
    connect ps3 to tv with hdmi
    connect suround sound with hdmi to tv
    (this might not work)
    if it dont work then
    and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
    Dec 31, 2009 | Sony HT-DDWG700 Theater System
    Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
    Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
    1. Connect PS3 to TV (you can use the current cable or analog cable)
    2. Turn on TV and set input to port PS3 is on.
    3. Make sure PS3 is connected via correct cable.
    4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
    Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
    Sony ps3 an samsung tv
    Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
    Hope this Helped.
    Jul 12, 2008 | Sony Playstation 3 (PS3) Console
    Connecting PS3 to receiver via HDMI
    First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
    hope this helps.
    CABLE GUY.
    Jun 24, 2008 | Onkyo HT-SR800 System
    Ps3
    first adjust the wires that connect the h.d tv and the play station once those are connected to one tv and connecting to other tv may not fit to the same tv so by ad justing wires if your problem is not solve then change the wires it will come normally and dont put that wires to other tv
    May 23, 2008 | Sony Playstation 3 (PS3) Console
    Dynex 32 in. LCD Flat-Panel HDTV Logo
    71 people viewed this question
    Top Dynex Televison & Video Experts
    Jaime Hernandez
    Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
