Question about Hoover Vacuums
On hoover steamvac F7425-900 brushes do not rotate. I have cleaned the filter
  • 796 Answers
May be the motor is the problem
Posted on May 15, 2008
    Guru:
  • 1,894 Answers
Check ur motors..
may be the supply or coils or supply is bad
  • dewan nafees ahmed May 15, 2008
    there is much chance of motor going bad.
    but make sure if motor is receiving proper supply at its terminals.
    Goodluck,
    Please don't forget to rate or accept the solution.
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes do not rotate when cleaning carpet. Is in carpet clean mode and will not rotate. I did clear the filter underneath.
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3)Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism
Oct 22, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do you change the belt on a f7441-980 hoover carpet cleaner
There are no belts on the SteamVac series. If you have a brush rotation problem, please check this:
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4)Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen
Oct 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Why did the brushes stop rotating?
Please check two things:
(1) The shutoff switch on the hood is NOT set to OFF for brush speed.
(2) Remove the red filter panel from under the cleaner, behind the brushes, and clean the hair/debris from the screen filter. Squeeze the two panels together, and pull down to remove from the pocket.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model 7210-900
Did you clean both filters? There is one on the tank and the other is from the bottom, it ha a red frame, pull it out to clean. Pull the brush block out, is the shaft that goes up into the machine broken off? If so replace the brush block. While it is out, trn the machine on and see if the square hole up where the brush block goes, is turning. If not then the turbine has gone bad. You can sometimes clean the turbine out, otherwise replacing it may be the best option.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
May 17, 2008 | Vacuums
Vacuums Logo
50 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
