Question about Microsoft Xbox 360 Console
My xbox 360 will not show any pics, but I have sound. What may be the problem(s)???
  • 4,102 Answers
Hi, the first thing you should try is unplugging it all from the mains then remove all the wires from the xbox and the back of the telly, then plug them all back in.
doing this will remove any static that may have built up as this can cause you problems, now leave the xbox off for an hour to let it cool down fully then do the following.
1 make sure the air vents are free from dust vac them out if needed.
2 dont use your xbox whilst it is lying on carpet
3 dont use your xbox whilst its on top of anything else electrical as this will give off heat and cause it to over heat.
after you have done the above plug it all back in and switch it on, if you still have no sound or picture then the next thing you need to try is getting another video lead try and ask a friend if they can bring one round just for you to try yours with then if it works you need a new lead but if it dont work keep reading.
if you have got this far then i take it your xbox is still not working as it should do, now the reason you have got either no sound or no picture is due to it over heating, when they built these they used silly little x shaped clamps to hold the heat sink onto the gpu and cpu chip now these clamps are not secure and cause it to over heat.
check you have any warranty left on it before you get any work done.
if you have warranty left take it back and get an exchange or refund, if you have no warranty then the only option you have it to get the xclamps replaced and this may fix your xbox say out of every 10 i do only 1 wont work after it has had the clamps removed and more secure heat clamp fixing screws fitted it usually stops it over heating.
this is a big job to do and if you have never had a go at this sort of thing before then the chances are you will do more harm than good.
i charge 25 pound plus parts to fix these and the parts cost less than 5 pound so you need to find someone who is going to charge the same to fix the problem for you.
if you are going to do it your self then your going to need to get an xbox 360 repair guide and also the rrod repair kit and also some heat sink paste, its not easy to do and its a nightmare just taking the cases off let alone removing the heat sinks and old heat sink paste.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 14, 2010
New rca hd tv and xbox 360 can,t get pics or sound
Have you tried it on another tv???? If so and have also tried another set of av hookups.....i would suspect your output has crapped out of your 360....older ones are known for this
Nov 13, 2012 | Microsoft Xbox 360 Console
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
I have one red light on my xbox 360 elite with code E 73
https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
hope this helps its two ebooks on how to repair red light error ,full instution plus pics show u how.this download is only there for 7 days or 100 downloads.DT
Feb 23, 2010 | Microsoft Xbox 360 Elite Console - Black
My 360 has sound but no pic helpp
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Or you can send it in and have it fixed.
Jan 08, 2010 | Microsoft Xbox 360 Console
My Xbox 360 will not show a picture you can hear the sound but there is no picture.
1) make sure the video cable is firmly inserted into the back of your xbox 360. Sometimes a loose connection will produce this result.
2) Check the end to your television set and make sure it is in correctly. Is this HDMI ??
3) Cycle the inputs on your tv until it gets back to your xbox 360 and see if the picture appears.
4) If you have this hooked up via HDMI, connect it through another method and go into the video settings in your xbox 360 dashboard and set them to auto detect.
Let me know if this helps.
Jul 28, 2009 | Microsoft Xbox 360 Console
Show me how to set up
http://support.xbox.com/support/en/us/nxe/Hardware/Console/SetupYourConsole/ConnectToTv.aspx
heres a link to microsofts website that link goes to a pic on how to set up your 360 to a tv if you have any more questions let me know
Jul 01, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont show picture or sound
if your xbox doesnt show pics or sound you should send it back to the xbox company and they will fix it for you. do not open it up and fix it yourself. all you have to do is pay shippping which doesnt cost that much......... hope this helps
Jun 06, 2009 | Microsoft Xbox 360 Console
Sound but no pic
One of the cables which gives you the picture will be switched on HD instead of just tv there a little switch on the side on the the cable
Mar 23, 2009 | Microsoft Xbox 360 Console
No pic on 360
do a status check and it should tell u and after that wat ever seems be the problem read by selecting mor info then call 1-800-469-9269 and tell them about it and they will troulble shoot unless u have xbox live send 2 xbox/support hope i have helped u with ur problem if not then srry
May 22, 2008 | Microsoft Xbox 360 Elite Console
Xbox 360
On your AV cord theres a switch that changes it from HDTV, to TV
Make sure its switched to TV if your not using HDTV, or switched to HDTV if ur using that. If you need pics let me know I can get you some so you can see where the switch is.
If that doesn't resolve it check your cords, make sure the cords match the colors.
Oct 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
