Question about Orion TVDVD092 9 in. TV/DVD Combo
Orion Model TVDV D092 075580501079 Purchased 9/17/06 Snow on EVERY channel --- My other TV is fine on all of its channel. Can you help me???
  • Orion Master
  • 17,129 Answers
Please try and use your AV input or play the DVD inthe combo to see if there is a perrfect picture.
If so the Tuner module is faulty and may need a replacement.
This can be confirmed if you can take a final voltage check to see if the tunerr receives the +12 necessary for the functioning . If not the regulator can be faulty.
The tuner must be replaced with the same type pin configutation , must be taklen out of the board witth good carre so as not to damage the PCB and resoldered.
make sure your cable input lines are good and there is no short in the splitters coming to your house in case your are using community cable.
Posted on Sep 14, 2010
I have anew orion tv model no.tv1934a an I was asking if it's a digital tv.because I have a antenna but I can't pick up channels?
This model is not digital.....to receive digital channels you need a digital set top box or another type of digital receiver to get any channels!
Feb 01, 2015 | Orion Televison & Video
RELENTLESS SNOW
You shouldn't have to have the tv to channel 3 or any other for that matter if you are in component. You need to make sure the tv is on the component input from your display menu that can be accessed from your remote.
Nov 12, 2013 | Mitsubishi VS-60805 60" Rear Projection...
I have a Orion Standard television. I have hooked up an antenna but no channels are being found. Why can't any channels be found?
check the settings in the tv, select 'AIR' in the option. if still no channel receive and it has only a raster like a snow the cause would be a bad tuner board.
Dec 02, 2012 | Orion Televison & Video
We have an orion model 1934 tv and can only pick up a few channels on it-less than 12 and it is hooked to our cable which has 70 channels access. this is a 2002 year make so i think it should pick up a lot...
If you can, go into the ch set menu and change it from tv to catv(cable). then run the auto ch memory. I hope this helps. Orion's free help line is 800 289 0980.
Dec 17, 2008 | Orion1934 19" TV
Orion 2501
use your remote and fine tune the channel 15
Oct 02, 2008 | Orion1934 19" TV
External input
I'm not overly familiar with your brand, but generally there are 2 ways to get to the AV input.
1) Use the TV/Video button on the remote (if there is one)
2) Channel up or down from the last channel at the high or low end. In other words: channel down from channel 2 may bring you to the AV input.
Hope this helps,
Dan
Sep 23, 2008 | Orion Televison & Video
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Televison & Video
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
Orion TVDVD092 9 in. TV/DVD Combo Logo
74 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
