Typewritter won't correct!
We have an IBM Selectric II Typewritter that will not correct. When you press the correction key it goes back but the typewritter ball and correction ribbon don't engage at all. They correction key is merely acting as a backspace key. Any suggestions? Thanks for your help!
  • wflowers1 Feb 10, 2009
    We have a Selectric Model 85, it works perfect, except the correction tape does not engage. It goes back when you hit the correction key and we type the wrong letter again but it does not erase it..Please help
  • Anonymous Mar 21, 2014
    typewritter making a constant beeping (alarm) sound. seems problem is that the ribbon cartridge is not snapping in place.
  • 3,594 Answers
After you press the corr. key you must retype the wrong letter then type the correct letter.
DickyO
Posted on May 16, 2008
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
How do I remove and replace the tab set/clear button on an IBM correcting selectric II typewriter
Yes, all the keys are snap on. Use a spring hook on top and bottom of the key and wiggle (carefully) upwards to remove. (If you don't have spring hooks, then hefty paper clips will do. Create a 90 degree or better bend on the end of the clip)
Nov 27, 2014 | IBM Correcting Selectric II
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
Typewriter keys sticking
Your Selectric may need cleaning.
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting selctric II keys are jammed
It sounds like the cycle shaft is not fully in home
position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
Feb 18, 2009 | IBM 3500 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
193 people viewed this question
k24674
jasbo
jasbo
