Question about Dell Inspiron 1100 Notebook
I'm trying to update my Inspiron 1100 to (2) 512mb PC2700 DDR 333Mhz SODIMMs (per Crucial) with no luck. Presently have (2) 12mbk PC2100 DDR 266Mhz that work. I have updated the BIOS to A32. As I am seeing this is a common problem with no clear answer, I was told this was a simple plug and play upgrade...BS. I get 2 flashing lights on either side of the caps lock and then shut down. I am pretty sure the SODIMM's are seated but even with one chip or the 128 in "A" and the 512 in "B" it will not boot. No combination works. It's a 2.40 Ghz processor so if I could pick up the ram, it is worth keeping. Any help??
  • jds1469592 Sep 14, 2010
    You said no combo works for you. How about putting the ram as it was stock? Crucial is very good at getting you replacement ram if needed.
  • 2,427 Answers
The system mb doesnt support the 333mhz click speed. You need to get memory that 133 - 266 mhz's.. other than that you will need to upgrade the mb to support 333 mhz,, which sadly you cant get 1 to fit in that unit.. another thing to remember is that you cant mix two different clock speeds .. for example 133 and a 266 mhz..
1 thing you can try is to overclock the system..
1.) enter the bios (press the designated key shown on the boot screen to enter cmos or bios settings)..
2.) change the Clock speed to 333..
3.) save and exit..
4.) shutdown
5) insert 512mb sticks
turn on and hope for the best..
Whats strange enough is that the overclocking seems to work on some and not for others,, I think it has a lot to do with the chipset and the brand.. not sure..
let me know if it works or maybe we can try something else,, I'll post again based on your reply.
Posted on Sep 14, 2010
Which ram do i need?
You need DDR SDRAM like this,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231039
Best value for the money
Have a nice day!
Aug 31, 2011 | ASUS P4G800-V Motherboard
I have a Biostar Motherboard K8M800-M7A and i just recently bought a kingston ram memory 1GB 400mhz KVR400X64C3A. Everywhere i look for on the internet says they are compatible but i dont get them to work....
You are correct, this motherboard can use either 333mhz DDR (PC2700) or 400mhz DDR (3200) chips.
You may have a bad chip. Also make sure you are not mixing this chip with another of another speed. Its not good practise to mix 333mhz and 400mhz though some motherboards will still work like that.
Your best bet for compatibility is crucial DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 128Meg x 64 •
Personally I have had bad luck with kingston ram myself.
Chris
May 19, 2011 | Computers & Internet
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system....
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
Mar 13, 2011 | ASUS P4GE-MX Motherboard
I HAVE AN 3003WLMi ACER LAPTOP, WITH 256 DDR AND 60 GB HARD DISK , HOW MUCH MORE DDR RAM CAN I EXPAND TO. THANKS
Here is what I found:
You can upgrade your Acer Aspire 3003WLMi upto a maximum of 2.0 GB, with maximum of 1GB per slot in 2 memory slots. The Acer Aspire 3003WLMi takes the PC2700 DDR SDRAM SODIMMs Memory Type.
From: http://www.buycomputermemory.com/memory/AcerAspire3003WLMiMemoryRAM.html
Dec 13, 2010 | Acer 3003WLMi Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
RAM upgrade is not working
A 200-pin PC-3200 SODIMM should work in your machine but it will clock down to 333MHz. Your computer has 2 slots with a max of 512MB per slot (1GB total system memory). For maximum compatibility you should stick with a low density (16-chip - double-sided) PC2700 DDR-333 SODIMM with a CL of 2.5. Link below to see an example:
http://crucial.com/store/listparts.aspx?model=Pavilion%20ze4300%20Series
-E
Dec 25, 2008 | HP Pavilion ze4365us Notebook
Verify memory upgrade in a Inspiron 1200
Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Standard Memory 256 MB (non-removable) Maximum Memory 1280 MB Memory Expansion 1 socket Memory Comments PC2700 DDR SDRAM SODIMMs. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | Dell Inspiron 1200 Notebook
I want to up grade my RAM
I'm afraid the highest frequency ram for your laptop is DDR 333. The highest capacity is 1024MB DDR333, 333MHz, PC2700, 200 pin SODIMMs.
Nov 18, 2008 | Dell Latitude D600 Notebook
Upgrade memory in a Xerox 7400.
Unfortunatly you have to have the memory stick from Xerox.
Aug 07, 2008 | Xerox Phaser 7400DN Laser Printer
How much ram?
hi yolkel.
try this site crucial run the test it will show you what your motherboard can hold.
riz.
Jun 05, 2008 | MSI : MS-7061-020...
Dell Inspiron 1100 Notebook Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
