Question about HP Pavilion a705w PC Desktop
When my computer starts the power light will blink and the fan starts. When the computer first had problems it froze and the fan turned on and wouldnt stop. I also smelt a burnt rubber smell. I read to test the power supply with a tester, is that a voltmeter you are refering to?
  • add37j Oct 30, 2010
    I only asked about the voltmeter scale because when i have a problem i want to be a meticulous as i can in explaining it, so it is known exactly what the problem.
    I havent gotten around to checking the power supply yet, I have been busy @ work.
    I believe what you listed is the processor i have. I did clean the top of the processor and the case. I did not, However use anti static precautions, I knew nothing of it.
  • HP Master
  • 5,660 Answers
Just to add;
Use a Multimeter. One that is good enough for this application will range from $10 to $12. You can find an economical multimeter in a variety of stores. An auto parts store is but one place. Analog or digital, doesn't matter.
The function knob in the middle of the multimeter is set to the DC Voltage scale.
The DC Voltage symbol is one straight line with a dotted line above it.
(AC Voltage symbol is a curved line. This = No)
If there are different DC Voltage range settings for the Function knob, set it to the 50 Volt scale.
The Positive probe lead is the Red one.
The Negative probe lead is the Black one.
The Positive probe lead touches the Power wire.
The Negative probe lead touches the Ground wire.
Wires coming out of the Power Supply, and their color code:
You will be concerned with three colors of wires.
1) Orange = 3.3 Volts
2) Red = 5 Volts
3) Yellow = 12 Volts
ANY Black wire is a Ground wire.
I suggest you check any unused 4-pin standard Peripheral power cable.
It has one Red wire, (5 Volts), one Yellow wire, (12 Volts), and two Black wires. (Ground wires)
Look like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The Positive probe lead tip goes into the socket hole with the Yellow wire, and the Negative probe lead tip goes into a socket hole with a Ground wire.
Read to see if you have 11 to 13 Volts.
Less than 11 volts means it's time to replace the Power Supply.
Same for the Red (5 Volts)
4.5 volts to 5.5 volts indicates okay.
Less than 4.5 volts means replace.
I also found this Multimeter tutorial online just now,
http://www.ladyada.net/learn/multimeter/voltage.html
Posted on Sep 14, 2010
  • 2 more comments
  • add37j Sep 23, 2010
    I thought originally it was the processor. Took out old processor and end up buying the wrong on 1. The I got answers from this site. I put the processor back in with new heat sync on it. I plugged computer in. The Light is Yellow. Both fans start. Compouter will not power down, it has to be unplugged. I checked one of the peripheral cables, the DVD/CD Player. It tested at
    11.95 yellow/ black and 5.14 red/black. Checked at 20 and 200 DCV. I dont have a 50 Volt setting. Would I also check the main cable coming out of the power supply?
  • joecoolvette
    joecoolvette Sep 24, 2010
    1) Sorry, 20 Volt scale, 50 Volt scale, whatever applies. (Different multimeter's have different settings for the Function Knob)
    2) Yes, check the 3.3 Voltage power rail, by checking in your 20-pin ATX main power cable.
    http://www.playtool.com/pages/psuconnect...
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Scrolling down the page, the motherboard illustration lists the 20-pin ATX main power cable's connector on the motherboard, as Conn 1.
    Referring back to the PlayTool link above, test any Orange wire, (3.3 Volt), with the main power cable plugged into the motherboard, as shown in the photo to the far right.
    See if your multimeter probe will go down into a socket hole with an Orange wire.
    (Right next to the wire, and down into the socket hole)
    NOTE*
    At the END of every wire, going down into the back of the main power cable's connector, is a metal terminal.
    The probe lead must touch that metal terminal. (Female. Plugs onto a pin coming out of the motherboards main power cable connector)
    The insulation of each power wire, goes down into the main power cable's connector (Socket hole) pretty far. The probe of the multimeter must touch the metal terminal at the end of the wire.
    The Positive (Red) probe lead of the multimeter to an Orange wire, the Negative (Black) probe lead to any Ground wire. (Ground wires = Black. Not to be confusing, but Ground is also Negative)
    3) Does your Pavilion a705w have the base Processor?
    The Intel Celeron D, model 340, at 2.93GHz? (Socket 478)
    http://en.wikipedia.org/wiki/List_of_int...
    (Part Number RK80546RE077256)
    As you can see in the Wikipedia link, the Intel Celeron D model 340, runs on 1.25 to 1.40 Volts.
    It could be the 3.3 Volt power rail, (Orange wire) is the power rail providing power for the Processor.
    May I also ask if you have been following Anti-Static Precautions, and how you applied the fresh, new thermal paste, (Also known as Thermal Grease), to the top of the Processor's case?
    A Processor is the Most susceptible hardware component to Static shock.
    Did you thoroughly clean the top of the Processor's case before applying thermal paste?
    Use Q-tips dipped in Isopropyl Alcohol? (Also known as Rubbing Alcohol)
    [CAUTION!
    Isopropyl Alcohol is Extremely Flammable!
    Use in a Well ventilated area, with No sparks, or flames present ]
    Is the Socket 478 bracket on the motherboard in good shape?
    The new Heatsink is locked securely into it?
    Heatsink is sitting flat? There is no perceptible light showing in-between the top of the Processor's case, and the bottom of the Heatsink?
    (I remove the motherboard, and get a 'birds-eye' view across the side of the motherboard, for this)
    I brought up the voltmeter scale because I want to explain everything.
    I have not gotten around to checking the power supply yet, I have been very busy at work .
    I do believe that processor you listed is the one I have. I did clean the processor and the bottom of the fan, w/ alcohol. I did not however, use anti-static precaution's, I knew nothing of it. I also spread the grease with my finger. A few of the pins on the processor were bent, so I tried to bend them back. I think it did sit flat and tight in the socket.
    I thank you for your time and knowledge.
    John
  • joecoolvette
    joecoolvette Oct 30, 2010
    I use a mechanical pencil, ('EverSharp') to straighten Processor pins. A Processor is the most susceptible computer hardware component to Static shock, and was touched by your fingers. How about a Celeron D 325 (2.53GHz) for $14?http://www.weirdstuff.com/cgi-bin/catego... (Not advertising. I've used these guys before, and have always received good working parts)
  • HP Master
  • 32,281 Answers
Yes the voltmeter measures the voltage.
When you power up the computer to test the voltage on the 4 wire connectors.
Test the voltage red and balck wire should read 5 volts.
Test the voltage yellow an black wire should read 12 volts
If the burning smell is from the power supply then most likely a capacitor has blown in the switch mode power supply.
I would advise you purchase a new power supply, do not try and repair it, these mains devices can be dangerous if you don't have knowledge.
Why my laptop wontturn on and has constant blinking lights
This problem could stem from a number of different things. I will cover what each light blinking would mean.
Low Battery
If when you try to turn the computer on the light near where you plug your computer in blinks, that means that you need to plug your laptop in. This is probably what's wrong because the PC is not turning on.
This could also be the case with pressing the on button, if your on button has a light on it. It could also mean the computer is in sleep mode, and you have to force it off and back on if it is stuck there.
Sleep mode problem
If the light on your on button blinks when you try to power it up, it could mean that the computer froze in sleep mode, and you need to hold the power button down in order to solve the problem. When the computer forces shutdown you will hear the fans, etc. stop. You can then turn it back on again.
Battery Problem
If you're certain the battery should be charged, and it still doesn't work when not plugged in, there could be an issue with either the a/c adapter or the battery and you may need to replace them in order for your computer to perform its best. If that option is not available to you at this time, you could always just use your computer when its plugged in, just make sure it doesn't un-plug :)
Aug 14, 2014 | Compaq Computers & Internet
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
Hi. I went to switch on my HP Pavillion Laptop one day when it unexpectatly froze during startup. I clicked the power button of the laptop and everything seemed fine with the lights turning on and the...
That blinking cursor is the way in which the BIOS of the laptop is telling you that it can't load Windows because it's too corrupt There's nothing more you can do apart a full reinstall. Use the recovery disk that has came with the laptop when you bought it.
Jan 15, 2011 | Computers & Internet
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Computer freezes on start up all I get is the blinking cursor on the upper left corner (looks like the DOS screen) waiting for a command to be entered. I force shutdown pressing and holding the power...
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 27, 2010 | HP Pavilion Elite m9500f PC Desktop
Gateway M-6834 laptop -- power blinks
Im having the same problem. did you find a solution?
May 14, 2009 | Gateway M-6834 Notebook
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
HP Pavilion a705w PC Desktop Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
