Question about Westinghouse Electric LCM-22W2 Monitor
At power up, screen flashes DVI, then screen displays "check source and connection" green light is lit for about 10 seconds and then monitor powers off.
  • 11,361 Answers
Check the DVI cable and all the pins, try it with another PC to make sure you are not having the video card problem, also try using VGA port to see if it has the same problem. Post back what you find.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 14, 2010
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Sep 21, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
How do you reset the monitor?
press menu button and choose display source. like VGA/ DVI or Display port.
Mar 28, 2015 | Hannspree Computers & Internet
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
My laptop hp have problem monitor giving mesage ''monitor going to sleep''
hi you will need to reinstall the vga of the system to enable it not to write that again
May 19, 2010 | Computers & Internet
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
Screen not working
check if the source is correct, VGA / DVI.
also make sure your resolution set on the computer is not higher or mhz is correct.
Mar 21, 2009 | ViewSonic VX912 19" LCD Monitor
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Dec 03, 2008 | Microsoft MNTR TYRIS|LCD 19' 8MS DVI...
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Westinghouse Electric LCM-22W2 Monitor Logo
111 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
pankaj rautela
pankaj rautela
Vernon Taylor
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
