Question about Matsonic MS9087C Motherboard
I have a Matsonic MS9087C main board. i've been running 1 512 stick and 2 256's in it for a while. i just purchased 3 x 1 GB DDR PC3200 / 400 mhz high density sticks. They are brand new and do not work in my system. My other ram works in there fine. What's my problem ? The mainboard specs say up to 3 GB. The only difference in my old ram and the new sticks is that the new ones have small black squaers on them rather than long black squares. all the specs match. Please help me.
Benimur
  • 6966 Answers
SOURCE: DDR PC3200 displays no video on LCD and Out of Range on CRT
Hi, If I may add to the other posts, 1. If the problem persist with the new or the old memory, then it is not a memory problem; 2. Jumper on Clear CMOS/BIOS and removing the small battery should set the system back to default, of course for normal operation, it should be set back to normal position; 3. It is possible that it is not a PSU problem, it is likely that the PSU is ok and just doing its job of switching off probably due to a fault at the motherboard; 4. The MB fault maybe be anything. Try removing everything except mb & front panel wires and the psu (video card,cables to your drives, memories). Check if on powerup, fans will spin normally and not just start then stops; if it works reinstall everything, if not: 4.1 Remove your motherboard from the back panel plate, remove the front panel connector/wires (it is a good idea to mark them down or copy how they are connected), remove power supply. Place mb on top of an old newspaper or something (as long as not metal or conductive), Install PSU power connectors, short/jump power on pins (where the front panel connectors/wires were connected before). If it works, your set to go, If not, maybe for some unknown reasons the mb is fried. Other possible causes of start/stop spin of fan: reset switch stuck, bent pins in memory slot, inverted IDE cable (though not likely but possibly), MB sensing fan is not or malfunctioning, fried CPU, BIOS (though normally there is a warning of boot block or something like that), no keyboard present. Of course, I am assuming that you have replaced the PSU with a new or known good one as you have comment/posted previous to this. Hope this works out for you and give you further ideas. Pls comment/post back should you need further information. Good luck and kind regards.
Posted on Aug 12, 2007
SOURCE: matsonic ms9087c boot hang and beeps
Try re-setting the bios jumper, it's by the battery.
Posted on Jan 02, 2009
marked
  • 6487 Answers
SOURCE: PC2700 or PC3200 DDR memory in this mobo ?
Yes you can use 2 X 1 GIG stick of RAM for thsi MOBO since the max RAM support is up to 2GIG...
Posted on May 14, 2009
brannfenix
  • 81 Answers
SOURCE: Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Posted on Aug 12, 2009
Testimonial: "thanks for reply.. I had installed it and PC booted but it was stucking too much..."
SOURCE: Memory
you can use ddr400 in slots 1&2 according to the manual but stability is comprimised just stay with 333
Posted on Apr 11, 2010
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Memory
the max RAM speed, type, make etc for your machine will be normaly be specified in the motherboard specs....if ur MB supports only 333mhz but if u add 400mhz speed RAM it may not work properly, check the MB mfg for the correct specs of the compatibility.
Feb 18, 2010 | Matsonic MS9337c Motherboard
Asus a7n266 c mbo has 1,512 ddr pc 3200 .an i add
you have to add memory with the same frequence.DDR 2700 or 3200
Not mixed togheter..
Jan 14, 2010 | ASUS Computers & Internet
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Ram selection?
Your motherboard supports max of 2 GB PC 2100 RAM. Hope this helps.
Jan 10, 2009 | E-Machines (40-A06600-D201) for M2000S...
Matsonic ms9087c boot hang and beeps
Jan 01, 2009 | Matsonic MS9087C Motherboard
MATSONIC
Try driverdownload.com or check manufactures website if possible.
Oct 09, 2008 | Matsonic MS9087C Motherboard
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
Matsonic MS9087C Motherboard Logo
77 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
