When typing the cursor either disappears or jumps to another location in the doc. How can I correct this?
  • 56 Answers
Control Panel, mouse, check your settings from there.
Posted on May 15, 2008
How do i fix keystrokes that jump backward as I type?
Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
Aug 12, 2014 | Lenovo Computers & Internet
While typing a story, the curser will jump backwards, and if I don;t realise it, I am typing between a previous word. Sometimes the cursur disappears from the page completely, and I have to use the mouse...
What's happening is that your finger(s) are touching/dragging across the laptop's TouchPad
while you're typing,
and thus the cursor's position in the document is being randomly reset/repositioned
while you're typing.
Solution: disable your Laptop's TouchPad, and use a mouse for cursor control.
Solution: tape a 3x5 index card over the Touchpad while you're typing.
Solution: type on a computer with a real keyboard, not the chiclet-type keyboard you (and I) are using.
Mar 28, 2011 | Computers & Internet
When I'm in the process of typing emails, sometimes the message just disappears; sometimes the cursor jumps to another area of the message and sometimes the cursor disappears! Any solution to this? I got...
Most of the time you can recover the message by hitting ctrl + z. the curser diapering may be a software glitch or a setting somewhere, and I do not have an explanation for the curser moving by its self except maybe accidently touching the sensor with your wrist, they use the heat from the part of your body that touches them so it is very easy to accidently touch it and not realize.
Jan 18, 2011 | Acer Aspire One Netbook 8.9" Notebook
Cursor jumps all over the place! Cursor "arrow" shifts to cursor "four-arrrow" then decides to change zoom level all on its own. Cursor disappears, is nowhere on the screen then...
The Touchpad is the cause. Although some work fine for years others jump the the pointer every time you type (or sneeze). You can turn the touchpad off if you have a mouse for the laptop. Otherwise, you might need to exchange/purchase another model laptop.
Oct 15, 2017 | Toshiba Satellite A355-S6930 16.0-Inch...
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
Over sensitive touch pad, causes cursor to jump all over the LCD
Try control panel and double click the mouse icon then settings you can adjust sensitivity there
Dec 28, 2008 | Sony VAIO FRV25 Notebook
Missing Cursor on Firefox
Hi there Lauren,
I think I've got you covered on this one.
I'd like to offer up a two solutions.
One may be the solution to the disappearing cursor.
Failing that, the other addresses the symptoms, instead of the problem, sort of a sideways solution. Hopefully the result will be satisfactory.
  • Click Start
  • Click Control Panel
  • Double-Click Mouse
  • Click on the Pointer Options Tab
  • In the Visibility Box, is the 'Hide cursor while typing' option checked?
  • If so, uncheck it.
  • If not, below it is an option to 'Show location of cursor when I press Control Key'. Check it.
  • Click Apply. Click OK
If the first option doesn't fix the mystery, the second will show the location of the cursor when you press the Control Key. One or the other will make that cursor show itself.
Mike
Dec 10, 2008 | Mozilla Firefox
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Steven
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Letter writting problems
Do you use a laptop or some sort of keyboard with a mouse pad? My son used to have that problem when he would type as his thumb would accidentally hit the mouse pad and move the cursor. We solved it in a very low tech way by taping a notecard over the mouse pad when he was using the computer. Depending on the manufacurer, there are ways to turn off the mouse pad while continuing to use a mouse.
Dec 24, 2007 | Microsoft Digit Media Pro bx100005...
Computers & Internet Logo
David Payne
David Payne
