Question about HP LaserJet 5L Printer
Have just bought a new desktop with Win7 and a usb to parallel cable to connect to the LJ 5L, I installed but it wont print. any ideas as to what the solution is? Could it be the cable or is Win7 incompatible with the LJ 5L?
  • 734 Answers
Your printer supports W7 and the driver is located below. You need to first unplug the printer, uninstall it from the control panel and then restart the computer. Then download your driver and install it. HP printers need the Full Version software, not the just the driver that W7 loads when it discovers it.
Do NOT plug the printer back into the computer until prompted by the software.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=15005&lang=en&cc=us&prodTypeId=18972&prodSeriesId=25480&taskId=135
Best Wishes,
Marcus
Posted on Sep 14, 2010
Hello, I have a HP LaserJet 5L; I just put in a new cartridge and its printing letters and numbers and not the doc. i'm needing...please help.
This error is not caused by the cartridge, it is either a cable issue or a driver issue. Try reseating the parallel cable on the back of the printer and make sure the cable is securely attached to the parallel port on the computer as well. Also make sure that you are printing with the correct driver.
Jul 16, 2011 | HP LaserJet 5L Printer
Is it possible to connect an old, still very efficient HP 5L Laserjet Printer which uses parellel port cable to a new computer via a USB cable? If yes, what do I need?
Yes it is. You just need a Parallel to USB adapter. Here is a link to an example of what you need.
Parallel to USB
I have done this several times with Parallel Receipt Printers. Works Great!!
Another option would be to add a Parallel Port to your new computer. Here is another link.
PCI Parallel Card
The 1st option is probably the cheapest and easiest.
Good luck and have a great day!
Feb 26, 2010 | Office Equipment & Supplies
I have a HP Laserjet 4P that had been used on my company laptop and home computer. When I upgraded top a new Dell Vostro 420 running Windows Vista Business and moved the printers over to this unit the...
You don't write how exactly is your printer connected - if I remember correctly, HP LJ 4P doesn't have a USB connector, and Vostro doesn't have the parallel port available.
So how did you connect it? Is it via some USB to parallel adaptor, or via JetDirect network card in the printer? There are multiple separate issues that may be applicable in either case...
Dec 30, 2009 | Office Equipment & Supplies
Lp 2844 will not work with my new laptop
You need a piece of software to create a Virtual com port, make sure you have the comms set correctly 9600, n, 8, 1 and print to that port, you will find it clearly marked in Device Manager. You can get a parallel to USB cable then you can use your driver set to LPT1
Nov 05, 2009 | Zebra LP 2844 Thermal Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Problems in printing from laptop to laserjet 5L printer
Try with other applications like Ms Word to check.
Jul 06, 2009 | HP LaserJet 5L Printer
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
HP Laserjet 5L feeds multiple pages through at a time
It prob. needs an overhaul/reconditioning/cleaning to soften up or replace the rollers and rubber pads in the paper path. I imagine it needs this about every 5-6 years. Don't know if new parts are still available for this great old machine, but it's worth trying to keep it alive, at least until you change computers and don't have a parallel output port anymore ;^).
Jul 26, 2008 | HP LaserJet 5L Printer
Vista connection -USB to Parallel Port Cable
Yes. Your product is supported. Drivers for HP printers are included with the Microsoft Windows Vista Operating System
HP has a Windows Vista driver solution available for your product. This driver will enable your product's basic functions to work. HP is committed to providing the best experience for HP products in the Windows Vista operating environment. You can conveniently find this driver in your Windows Vista operating system, today. At this time the driver will only be available on the Windows Vista operating system through the “Add a Printer�? wizard there is an alternative for this
remove all the drivers from add and remove program then
click start, then "run" type regedit, hit enter Registry Editor will open up.
Make backup of you registry, then on left side drill down to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
and check if you have "USB Monitor" key defined - If yes, you have different problem, this will not solve your problem. If not - right click on "Monitors" then click on new/key and name new key "USB Monitor" and then open this new key and on right side of the Registry editor under the (Default) right click select New - String Value this will create REG_SZ type value and name it "Driver" then double click to open it and in value data type "usbmon.dll"
Do the same thing to "Local Port" and "Standard TCP/IP Port" keys if you don't have them under Monitors key but you have them listed under AutorunsDisabled key. Then close registry editor, and restart, go to add printer/ local printer
Jun 26, 2008 | HP LaserJet 5L Printer
HP LaserJet 5L Printer Logo
61 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
