Ran hp diagnostics and got error code biome-1 It also said test memory 8192 mb. What does this mean and how do I fix it
    Scholar:
  • 181 Answers
The error simply means that you have a defective memory modules. If you have more than one memory module, remove all then install one at a time, this is to isolate the defective module.
Good day and good luck.
TedMac
Posted on Sep 15, 2010
My HP Pavilion Entertainment PC won't boot up but displays error code 1720 - S.M.A.R.T. Hard Drive detects imminent failure.
Replace the hdd, install your OS and copy off your date. Reinstall your programmes to recover your backups.
Nov 07, 2016 | HP Computers & Internet
HP Pavillion won't recognize Plug n play devices
Look into the Bios or System Setup and make sure Plug and Play is enabled. When you turn the system on notice what key it says to hit to get into the Bios or System Setup. Hit that key and check the Plug and Play to be sure it is enabled.
Apr 24, 2012 | HP Pavilion Media Center m9340f Desktop PC
How do I fix error code BIOME-1? That's what
One or more of the RAM memory modules are bad and must be replaced. You will need 2 of these if you have the pc above
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2968664&CatId=1872
Instructions http://www.youtube.com/watch?v=SiFIgSQOY7g
Jun 18, 2011 | HP Pavilion Desktop with Intel Pentium...
Hi. happy new year! my problem is it's not booting cp. i has check problem it come out memory (4096mb) error code(BIOME-1). what's problem that? can i change just new memory? thank you.
First try re-seating your ram modules to make sure they are properly seated. If that doesn't help try removing each module one at a time and restarting each time to see if start up is normal. Keep in mind to keep each module in it's original slot!!
You can also try this free test:
http://www.memtest86.com/ memtest86
hope this helps
Jan 07, 2011 | HP Computers & Internet
Is there a fix for biome-1 error
I purchased 2x2gb Ram sticks... along with a new case, I had them all installed by a client of mine who owns an IT company and I had the pleasure of waiting around for 4 hrs while they ran through all the RAM tests... PC works fine however as soon as I'm away for it for any length of time I come back and its continually rebooting. diagnostic says RAM test failure Biome-1.
Removed the RAM and fitted fresh, problem solved.
Hope that helps.
Jan 03, 2011 | HP Pavilion a6712f-b PC Desktop
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
I have a HP Pavillion a6500f and receiving the BIOME-1 error. I removed both memory cards and tested each individually and they worked fine (as single units), but when I plug both in I receive the BIOME-1...
You have a faulty port on the motherboard most likely, try the ports and see which one fails. You can either buy a new motherboard or just buy a bigger chip to use on one port.
Sep 17, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Hi there. I have an HP a6500f. Came pre-loaded with 4GB RAM. Worked fine for a year then started freezing/restarting/BSOD randomly. Ran memory diagnostics and got a BIOME-1 error with both sticks, but...
Try manually setting the ram timings in bios but....
i would think its a motherboard issue too by the sounds of it. find one that has a similar specification and fit it, I will suggest one if you need me to, just give me a list of the hardware you have installed on this current machine
Jan 14, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Compaq Presario R3000 2GB memory upgrade problem. I am having problems upgrading my Presario from 512 MB (2 x 256) to 2 GB (2 x 1GB). If both 1 GB DIMMs are installed, I get intermittent application...
Try a different brand of memory.
It is unlikely you can do anything with the memory you have to fix this problem.
The memory has the same specs as what another manufacturer recommends.
Be careful buying from auctions as they MAY be gradeouts. Always make sure you can return the product. Crucial has these for about $114 for your machine as an example.
Nov 13, 2009 | Compaq Presario R3000 Notebook
Computers & Internet Logo
869 people viewed this question
David Payne
David Payne
