Question about Kenmore 75085 Air Conditioner
Frost/snow on grill - Kenmore 75085 Air Conditioner
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Either the filter is plugged up and the air flow is reduced or the unit is low on freon and has a leak...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 14, 2010
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Freezer is snowing up and vents frosted - won't stop running
Thermostat is malfunctioning and needs to be replaced.
Feb 08, 2014 | Maytag Refrigerators
Bought this grill in june/july. first tank worked perfect. tank went out while cooking. changed to new tank and lit her up. low flame and went out. looked at tank and found the valve and hose covered...
turn off gas at tank remove hose let it deforst , open all burners on bbq run out gas in line , turn off burners, reconnect tank turn on slow , check hose for leaks with washing up liqued and water mix make bubbles with this mix and brush over joints this will prove if you have a gas leak (hence the frosting ) if this is good no leak then you should be able to light burners , if this leaks then it could be a new hose.
Sep 24, 2011 | Weber Spirit SP-310 Propane Grill
I have frost on the line coming from my gas tank to the burner on my Charmglow grill. Do I need to replace the flow valve. If so, what part number do I order and from where? Thanks, John
You need to replace the grills Hose/Regulator Assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. They run about $30.00. Take your old one with you for comparison purposes.
To avoid this happening in the future. Whenever, you turn the tank valve OFF and it comes time to turn it back ON, turn it ON VERY, VERY SLOWLY (Slow motion, slow). Doing it that way, won't lockup or blow the gas line regulator. It wasn't your fault, John (unless you didn't read the Owner's Manual). The new OPD tank valves, will shoot to high a pressure sometimes and either lockup the regulator or cause a small leak, like it did with yours. That's where the frost was coming from.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 16, 2011 | Brinkmann Charmglow Stainless Steel LP...
Coil frosts within 15 minutes in a warm room. After 1-2 hours they coils are covered with snow like frost 1 inch thick.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 30, 2011 | Goldstar DH304 Dehumidifier
This morning after heavy snow and frost my wipers on my 1998 proton persona don,t work
WIPER BLADES MORE LIKELY FROZEN STUCK. OR HAVE A LOT OF SNOW ON THEM. YOU HAVE TO CAREFULLY REMOVE SNOW OR ICE TO FREE WIPER BLADES THEN THEY WILL WORK AGAIN.
Dec 17, 2010 | 1991 Peugeot 405
The regulator and hose from tank to grill have frost/ice buildup - is this a sign of a leak ?
No, if it were leaking you would smell the strong odor of the gas. The gas is pressurized in the tank, when you open the regulator and light the grill, it is normal for the regulator to become very cold and therefore frost buildup. Cheers!
Sep 07, 2009 | Weber Genesis Silver B Grill
Frost accumlates instantly on a round metal thing with a hissing
This is a common sign of a leak and I would replace the flow control valve. If you continue to leave it on it will have very big problems
Apr 29, 2009 | Brinkmann Charmglow Stainless Steel LP...
On the interior roof warning lights there are two lights that keep coming on(orange and red) that look like snow flakes. What sre these warning lights for?
These are outside temp. warning lights. The Yellow light goes on when the outside temp. dips to 40 degrees to let you know that there is a possibility of frost. The Red light goes on when outside temp. dips to 30 degrees suggesting a possibility of icy conditions.
Feb 21, 2009 | 1999 Mercury Cougar
Frost in Freezer
it is a defrost problem,could 1 freezer fan not working2defrost heater in freezer not working3 defrost sensor in freezer not working and 4 defrost timer not working,if you have a volt meter you can check to find out which one it is,the easyest is to just look in the freezer and see if the fan is running to move the cold air,you might have to hold the freezer door button in to check it,let me know what you find-mike
Nov 12, 2008 | Refrigerators
Kenmore 75085 Air Conditioner Logo
41 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
