Question about GE Dryers
I am hearing a very loud chirping noise as my dryer works. I have disassembled the dryer in an effort to find the source of the noise. I found no obvious breakage. I intend on replacing the tub drive belt and maybe the bearing which attaches the brum to the rear of the unit. do you concur? I would appreciate any comments. the model number is ddg7189vslwh. Thanks
  • 145 Answers
The rear drum bearing is the most common place I see noise on this unit. You will also won't to check the front pads the drum rides on and the idler pully for the belt. GE parts can get expensive so I would look it over good before buying anything.
Posted on May 15, 2008
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post!
From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
Feb 07, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
96 Oldsmobile Bravada Engine Chirp
The water pump can also make the chirping noise. You can place a very long screwdriver or metal rod against the pump & place your ear to the end of it to localize the sound. A stethoscope is very helpful, if possible.
Jan 13, 2014 | Oldsmobile Bravada Cars & Trucks
Noise sounds like a metallic chirp from valve train.
To narrow it down, while the engine is running, don't get near moving parts, you can use a long piece of steel, metal, put 1 end on the valve cover, the other to your ear and listen for rattling. You can move it around to narrow down the source of the noise. It's like a stethoscope but works well. I use a 3' long screwdriver.
Jul 04, 2017 | 1999 Dodge Grand Caravan
My GE DBXR453GAWW is making a loud chirping noise
The rear drum berring is worn causing the chirp.
The motor berring is bad causing the chirp.
Service is needed to prevent fruther damage.
Jan 19, 2010 | Dryers
Very loud metal on metal screeching noise maytag model LDE8414ACE
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Loud metal-metal "screeching" sounds will eminate from the front bearing glides, (click on link below), for a picture of the glides. Link provided by www.repairclinic.com, they provide repair parts, disassembly procedures and diagrams.
You may also want to inspect for foreign objects in the front and rear drum seals and in the blower.
Drum rollers may sometimes cause loud noises also.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1309&PartID=1309
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1245880&PartID=1245880
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di400518&PartID=400518
Jul 16, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryer making chirping noise while drying.
If this is a GE/Hotpoint dryer then I can tell you exactly what it is. The rear drum bearing is worn down. WE3X75. To replace it you must remove the drum. This involves opening the door and removing all screws holding down the top. Then removing those holding the front on. Then removing the drum itself. This is not a hard job for a mechanically inclined indiviual.389d186.jpg
Jan 17, 2009 | Dryers
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Crosley CDE/CDG22b7
Please describe "rolling noise".
Oct 21, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
148 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
