Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Inside light does not come on all the time when door is open.
  • 1,056 Answers
Check if the bulb is loose. Turn it clockwise. This a common problem.
Posted on Sep 14, 2010
Dash light says drivers door is open when it is not open and stays on.
Possible defective door ajar switch. Usually located internal to the door lock mechanism inside the door. I have had some success spraying WD40 inside the lock assembly with the door open and then opening and closing the door several times.
Nov 29, 2015 | 2007 Toyota Camry
Drivers side door switch will not work at times, the lights on can not lock car and doom lights will not go off
For a temporary repair, spray WD 40 onto door switch, they stick.the switch is located in the door latch, open door spray inside where latch is, use plastic adaptor on can nozzle to get all the way around latch.the latch is what holds the door shut, you'll see it when door is open on door body.open and close it about 10 times to free up sw
Mar 18, 2014 | 2004 Mercury Mountaineer Premier
I got a mercury.. and the problem is the driver door some time it locks good all the way while start driving will lock, just like any other car. and some times it wont lock u can still drive but it will...
Your door ajar switches are located inside the rear faces of each door along with the latches. Just liberally spray a petroleum based lubricant into the door latch areas of each door (one at a time) and open / close the door several times. Once lubricated, your door ajar light, interior lights, and autolocks should function properly.
Good luck.
Apr 24, 2011 | 2002 Mercury Mountaineer
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
96 Ford Windstar the rear left cabin light and slidding door light stays on all the time and the sensor on the dash show that the doors are open when they are not. What can be causeing this?
Use WD40 spray and spry inside lock,Dirt can cause the sensor to stay open circuit either if it door is open or closed. Spray and open and close door few times, and repeat it till light goe's out.
Feb 21, 2010 | 1996 Ford Windstar
How to get to stop light in back window of 95 lincoln cont. Bulb is burnt out. do we change from trunk side or inside of car? also have a problem with interior lights staying on for a long time after car...
First, the stop light bulb is accessible from inside the car. The cover can be removed by pressing down on the center of the unit and pull back toward the front of the car. Once off, you will have access to the bulb itself
You have a sticky door switch. Apart from replacement, best course of action is to spray the switch (all throughout the inside of the door/lock) with WD-40. Since you're unsure which switch is sticking, repeat this procedure on all doors. Once thoroughly lubricated, open and close the doors several times. This should fix your sticky switch problem.. Best of luck.
Greg
Jun 08, 2009 | 1995 Lincoln Town Car
1996 Mercury Sable LS. Problem: Dome light and
One of the door adjar switches inside the door is sticking.
What works most of the time is to shoot some WD40 into the door latch it self then open and close the door several times,start with the drivers door.
Feb 21, 2009 | 1996 Mercury Sable
2002 taurus passenger door lock
Mine did this. I went around to each door and sprayed a liberal amount of WD-40 in the latch, then open and closed each door about five times. It hasn't done it since. I think the switch inside was not moving freely.
Dec 30, 2008 | 2002 Ford Taurus
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
