Question about Audiophase CD315 Personal CD Player
I have a 6 vvolt DC power supply that I was using use with the audio phase GD player. When I plug it into the player, The playere will not turn on. I unplug the power supply from the player and the player works fine.
  • 1,056 Answers
It may have a little switch so you can choose to either use it with a battery or with the power supply. If not try taking out the battery and see if it works. If it does not work with the battery taken of then it is the power supply. You can further check if the power supply is putting out voltage with a multimeter if you have one. Note that it might read a a few volts higher than 6 volts which is normal. If it reads less than six volts then it is no good.
Posted on Sep 14, 2010
How do I remove electrical interference on my dvd recorder?
Hi David
You need to figure out how the interference is getting inside.
Look at the external connections.
HDMI Cable or Perhaps the Power Connector.
Noise from the power cable would be most likely.
A Ferrite Bead can often be clipped onto power lead to dampen electrical noise. Electronics supply stores have these.
If an AC to DC external box is used. What is the required DC input to your DVD ?
For example if the AC is dropped to 12v DC and then plugged into player via a small connector. You could get your own connector and supply from a 12v vehicle battery. Be careful to maintain correct polarity to tip of connector.
Use a cheap multimeter to check voltage & polarity.
Substitution....This would prove that the noise source is from the Power Supply.
Cheers
Apr 07, 2015 | HDCVT SCART/ HDMI to HDMI Video Converter...
Samsung l300a dvd player - no video, only audio
Try to reset the player. Remove the DC power supply. Remove the battery. Leave it for 30 mins. Power on using the DC power supply without the battery.
Sep 21, 2007 | Samsung DVD-L300 Portable DVD Player
Where can I find solutions for a power problem ? The unit will not turn on
- It is an issue with the DC 9V 0,4A jack (Power Supply).
There is not a right connection with the middle part of the connector.
The male connector of the record player is designed much too small
(or the female one of the adapter much too large).
I have used a crimped ferrule opened a little with a nail before.
- or check the adapter: Output DC 9V 0.4 A Direct(!) Current not AC
- plus in the middle of the Jack
Feb 28, 2014 | Crosley CR8005A-TU Cruiser 3 Speed...
I bought a campact disc player (Durabrand; Model CD-896; made by Lenoxx Electronics Corp) which did not include AC adaptor. Now I am trying to find a matching adapter (DC: 4.5V 500mA). Can I find it on...
Power supplies with those specs are common online. Radio Shack could probably set you up with a universal power supply that adapts to all the common plug sizes.
web search "4.5V 500mA dc supply"
Sep 09, 2011 | Audio Players & Recorders
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
I am trying to connect my JVC KD-G340 car CD player to a headboard in my bedroom. I am using a radio shack A/C to DC power converter as a power supply. When I connect the Black Wire (instructions say to...
your ac-dc converter is not properly shielded or grounded, you need to replace it with a good one.(or you may wire you cd player chassis to a grounding receptacle, most ac outlets the center plugs are the ground terminals)
some car cd-player has a memory circuit, that will remembers on what state it was before power was remove, like yours it will play again as soon power is applied to it..
Feb 09, 2011 | JVC KD-G340 Car CD/ MP3 Player
No power to stereo.
use wiring diagram back of stereo. check 12volts supply by multitester dc.
May 30, 2009 | Kenwood KDC-5011 CD Player
Reads dc/dc error @ high volume
more than likely you have a bad ground and/or a power supply problem: bad wire connection, bad alternator - but check the radio's ground wire first.
Oct 15, 2008 | Pioneer DEH-P80MP CD Player
Audio phase
My audio phase MP3 player says "flash error! please backup the data and format the player.'' What does that mean? how do you fix it
Dec 28, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Audiophase CD315 Personal CD Player Logo
69 people viewed this question
Top Audiophase Audio Players & Recorders Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you an Audiophase Audio Player and Recorder Expert? Answer questions, earn points and help others
