Question about Dryers
The dry drum spins but there is no heat - Dryers
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 14, 2010
Hi my whirlpool doesent speen
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
Tumble dry wont turn and dry
check that your motor spins and your belt is on the drum. you say its heating so your door switch isn't the problem.
May 30, 2014 | Cell Phones
Hi, My dryer has stopped dying the my cloths is this a common problem?
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Aug 31, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
My dryer rumbles when it is spinning. But it also
The drum support rollers are worn. This will cause loose belt tension and a rumbling sound. You will need to pull the drum to find the rollers at the lower back of the drum. Check the roller shafts for wear and replace them at the same time as the rollers if needed. Check the belt and tensioner for wear before reassembly. This should fix ya...
May 08, 2010 | Dryers
Not drying clothes no heat
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 13, 2010 | LG DLGX7188 Gas Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
The drum is spinning, the heats working, not drying
Try washing both lint screens with soap and water and letting them dry.
Apr 04, 2009 | Asko T700 Electric Commercial Dryer
Load squeal
if you can take your dryer apart, you'll have to take the drum out and lubricate the bearing that is located in the center under the drum while there check wellness of your heat element if located there. Anyway use high temp grease on this bearing looks more like a ball
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a whirlpool dryer model LER8857EQ2. Drying drum is heating up but not spinning. How do I access the drive mechanism to determine why not spinning?
you have to take the top of the dryer off so you can see the drum to see if the belt is broken or the motor is bad
Jan 17, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
