Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor Oven Death
Hi All, The other day my Dacor ERD30 control panel lights went out and the oven doesn't work. Checked breaker and reset but no results. Top burners function fine.
I'm guessing fried circuit board? If so how much? (out of extended warranty by 4 mos of course…)
Any ideas would be greatly appreciated.
Thanks in advance.
geo Suddenly my oven isn't working at all; the clock is stuck at 4:15 and the "light" button for the oven works, turning the oven light on and off, but none of the other buttons will do anything - the top gas burners work just fine. I don't have a user manual and don't know how to get one. This is Model # ERD305068K. Thanks!
    Guru:
  • 1,894 Answers
I think ur breaker is dead
Posted on May 15, 2008
  • dewan nafees ahmed May 15, 2008
    i think some of the power board components are fried up.
    look up for the blown out components and check them.
    if found faulty replace them and try.
    Goodluck,
    Please don't forget to rate or accept the solution.
2 Suggested Answers
dovaleh
SOURCE: Dacor Oven Death
hi,
i think first you should call dacor, 4 months is marginal - they should cover it
but if all else fail you can try this link ti diagnostics manual:
http://dacorservice.com/PartsCatalog/docs/ProductModels/437/Diagnostic_Manual.pdf
and this link to dismanling instructions:
http://dacorservice.com/PartsCatalog/docs/Ranges/Service%20Manuals/ERD30s06_sm.pdf
good luck
dov
Posted on Jan 10, 2009
Dacor ERD30 oven trouble
HI,
Check if both circuit breakers for the oven are on.
The control board needs only 120V but it should be 240V for the heating elements to function properly.
Check if there is 120V coming to the thermal fuse.
when you get your meter . put the oven on bake and check your power on the bake element if you do not have 240 volts then your control board is bad. if you have 240 volts then you element is bad.
Goodluck,
Please don't forget to rate the solution.
Mar 25, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
ERD30S- oven wont turn on
Hi! jpdufilho
Try tuning off the power to the unit for 20 minutes. If this does not fix the problem you may need a new control board/panel. If you have a lot of lightning in your area you should have several surge protectors in your house. All electronic devices need some type of surge suppression.
InMrFixIt
Nov 09, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERD30 will not reach or maintane setpoint
read your owners manuel and follow the instructions for adjusting the oven temp set it 15 degrees higher
Dec 31, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Oven Death
hi,
good luck
dov
Nov 20, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven not heating after self-cleaning cycle.
That did it for me too. You saved me a $200 service call!
Nov 05, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
440 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
