Question about Lakewood Oil-Filled Electric Radiator Heater
How oftern does one need to refill oil in oil-radiator heaters? To this, I mean any oil-radiaor cos i am about to make a decision to buy one in place of the electric ones I am used to.I need something that heats up really well for winter
  • 455 Answers
Hello The heater is factory sealed & does NOT ever require filling it uses electricty to heat up the oil inside for heat.
Posted on Sep 14, 2010
Radiaor is pushing water back out of reservior and over heating
Radiator must be rodded out at radiator shop.
Feb 08, 2013 | Water Heaters
Tip
Oil Filled Radiator Heater Leaking
<p>A very common and increasing popular source of <b>supplemental heat</b> in the last few years has been the <b>oil filled electric radiator. </b> <br /> <p>These <b>radiator heaters</b> are filled with an oil that circulates through the fins of the heater and is heated by <b>electric heating elements</b>. The result is a steady even type of heat that has a lower surface temperature then many <b>space heaters</b>, making them a great way to get <b>supplement heating</b> into a room when you have pets, small children or combustibles near by.<br /> <p><br /> <br /> <p>One of the big questions that comes up with these <b>oil filled heaters</b> is what to do if they start to leak. The answer is that if the<b> oil heater</b> starts to leak then it is no good anymore and needs to be disposed of. These<b> heaters are filled with oil</b> at the factory and then are sealed tightly. Because of this there is no need to ever <b>refill the heater with oil</b> again. The heaters are sealed with the proper oil inside for the <b>best heating efficiency. </b> <br /> <p><br /> <br /> <p>So what this means is that if you have one of these <b>oil filled radiator heaters, </b>you will never have any <b>maintenance</b> or worries about <b>adding oil to the heater</b>. But if there ever is a leak then the heater is also no good and will need to be throw out and replaced. Very few of these <b>oil filled heat units</b> ever leak, but as is always the case there are always some that do.<br /> <p><br /> <br /> <p>A word of caution about heating efficiency. Always remember that when <b>heating with electricity</b>, the <b>laws of physics</b> always apply. <b>For every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br /> <p>There is no way to get any more or any less than that, so if anyone tries to tell you that their electric heater is more efficient then the next one they are not telling the truth.<br /> <p><br /> <br /> <p><br /> <br />
on Jan 12, 2011 | Heating & Cooling
Where do I refill and with what type of oil. The Comfort Zone model# CZ 9009
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
heatman101
Mar 30, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
How does one refill lakewood heater ?
These are sealed oil heaters and do not require refilling, if yours is leaking then it is bad and should be disposed of. They should not use oil or leak oil ever.
Dec 28, 2010 | Lakewood Oil-Filled Electric Radiator...
Model ho-0218 at a given time can the mineral oil be refilled
hi , i have to ask why would you want to refill it , if the heater is leaking its rarely econamical to fix the leak and repair it , most of the oil heaters ive worked on were filled with vegetable oil .
Oct 15, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
RADIATOR.
remove radiator and power wash fins they could be blocked then install again then get a good engine flush drain water then refill with flush and water then start and drive read the flush bottle for instructions then let all out again then refil with clean water and a good coolant , remember to blead the system when filling every time you drain water etc, hope this helps. it will work.
Aug 24, 2009 | 1992 Cadillac Seville
Where do you refill the oil at
Oil heaters are not meant to be refilled. The oil is inside the heater already. If you need to add oil, the heater is defective. Do not use it.
Dec 16, 2008 | Lakewood Oil-Filled Electric Radiator...
Lakewood Oil-Filled Electric Radiator Heater Logo
493 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
Paul Carew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
