Rheem 62-24084-01 Furnace Ignition Control Board wiring instructions or diagrams.
  • 147 Answers
SOURCE: I replaced my Rheem Ruud
When the purge motor turns on, the controller is waiting for proof that it is running before ignition. On your model I think it a differential pressure switch and it should be in front of the furnace. Should be able to see a pressure or vacuum line running to. If it isnt there there may be a switch inside purge motor. If there is more than 2 wires running to the motor it probable is there. Anyway the controller is waiting for proof.
Posted on Nov 05, 2008
  • 10 Answers
SOURCE: blower fan wont shut off
Try cycling the switch at the furnace to reset the blower board. If this doesn't work remove the green wire from the blower board(computer board) to eliminate a shorted t-stat or shorted wire between the furance and t-stat. If blower remains on, then blower board is shorted. I've seen all these problems.
Posted on May 04, 2009
  • 10 Answers
SOURCE: I have a Rheem Gas Furnace with an old analog
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Posted on Dec 07, 2009
SOURCE: Trouble shooting manual for Model# RGUJ-05EA-ER RHEEM GAS FURNACE
replace the gas valve....test for 24volt at the gas valve input.  if you have this then it's a def gas valve relay not working.
Posted on Dec 29, 2009
  • 51 Answers
SOURCE: wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Posted on Apr 13, 2010
Where do the five wires and jumper connect on my CamStat blower control. Older Rheem furnace.
Should be a wiring diagram inside the unit door or on outside. don-ohio
Dec 23, 2016 | Heating & Cooling
Rheem furnace ,2nd green light blinks 5 times then pauses. I have only 1 furnace,not a twin
5 flashes is a "neutral polarity failure".
on the motor:
White is the neutral and must be plugged in to one of the 3 neutral slots on the control board (usually on the left side of the board)
The other 4 wires (black, red, yellow, brown) are power to the motor and should be connected to the appropriate pins on the control board.
ref: http://www.rheem.com/docs/FetchDocument.aspx?ID=d0613a32-db55-4e32-abfd-04e89e72f7a6
Sep 13, 2014 | Heating & Cooling
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
My Rheem gas furnace will not kick on at all when set to auto. When I mannuly turn it on it does not put out warm air it just blow cold air.
Sounds like you may have an error code stored on the control board. Look for a small viewing port and look into the furnace cabinet for a blinking light. Once you find the light, remove some of the front panels and look for a wiring diagram pasted on one of them. There should be a diagnostic chart on the wiring diagram assisting you to pinpoint the area of the furnace that has an error. Good luck!
Mar 14, 2010 | Heating & Cooling
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
Dec 06, 2009 | Heating & Cooling
Rg(bu)h-07eauer have replaced the control board will not heat
read wiring and make sure flame sensor is clean and make sure you have good ground
Oct 16, 2009 | Heating & Cooling
Dec 09, 2008 | Heating & Cooling
I replaced my Rheem Ruud 62-24084-82 Ignition Module Control Board in my Rheem gas furnace last year. Has worked great until last night. Now blower purge motor starts but does not go into ignitor cycle. ...
Nov 05, 2008 | Ruud Heating & Cooling
Heating & Cooling Logo
547 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
