Question about Pacific International Mongoose 26 in. Mens Tactic
My chain keeps locking up or slipping, i just put a new rim on, i tryed to fix it but now use, how will i fix it?
  • 186 Answers
Check to see if all chain rollers between the links are there.if one is missing then your chain can slip.What are the sprocket teeth like.are they worn?
Posted on Sep 14, 2010
How do i fix a slipping chain drive
U cud hav a worn chain. U need to torque down the bolts that loosen it. Dont put tumuch strain on chain..it mite break and cause an injury
Sep 18, 2015 | Garden
18" chain keeps slipping while trying to cut oleanders, Is there some way to make the chain more stable?
You need to adjust your bar & chain tension as described in your user manual. Here is the location if you have misplaced: https://images.worx.com/en-us/manuals/WG300%20WG303%20WG304.pdf.
Basically you will take the "large knob" cover off, tighten the bar tension and put the cover back on. This will provide you with additional adjustment tension as needed.
Mar 23, 2015 | Worx WG304 - 18" Electric Chainsaw
Chain keeps slipping of the chainring
put chain on and tighten by pulling wheel back then tighten wheel nuts
Aug 01, 2012 | Schwinn Suburban Sport 26 Women's Comfort...
On mountain bike the chain or peddles seem to slip or click goning up a hill. Is it the chain slipping or worn gear?
It sounds like your chain is loose. Flip the bike over and loosen up the nuts on the back tire and tighten the nuts as you are pulling the rim back making the chain as tight as you can. You might need someone to help you pull as you tighten the nuts.
Aug 26, 2011 | Cycling
My new moongoose mischief keeps getting loose chain and pedals, ive tightend it up sevral times but keeps doing it, and the pedals keep loosening from the body??? anyone know how to solve this/
My first thought about the chain continuuin to become loose, is that you need to loosen the nuts on the back wheel, and pull the wheel (while the chain is still attached to bot hsprockets) in order to remove any slack. If it's a continuous issue, chances are that back tire keeps migrating forward because those nuts aren't tight enough.
To the pedal issue-If the pedals are wobbling or vibrating because the aren't snug while on the pedal bar (the bar that the pedals revolve around) it is probably because the peddals are too large. Try buying a new set of pedals. If they are loose and trying to slip off of the pedal bar and if you have tightened the nuts that keep the pedal on the pedal bar and they are continuing to become loose, it could be that you need to use locking nuts.
A quick fix to solving loose pedals is to add washers to the end of the bar until the washers are flush up against the pedal and the nut.
Happy pedaling!
Mar 23, 2011 | Mongoose Mischief Mag BMX Bike
20 month old 3900 Polaris, Drive chain keeps slipping off of toothed sprocket. No teeth missing on sprocket. How do I keep chain from coming off?
Check the float on the back of the machine. Mine was full of water. As soon as I replaced it , everything ran perfectly again.
I tried every possible 'obvious' solution, from new wheel bearings to a new chain tensioner-thingie. You will notice that there is actually relatively little room for the chain to slip off the drive gear.
Seems that this additional weight a) turns the float into a sink and b) provides enough drag to force chain slippage.
After replacing the float, everything runs perfectly again. Of course, our friends at Polaris have now decided that you cannot simply buy a new float. You have to buy the ENTIRE BACK, paying 90 bucks for something that should cost no more than 10 - 15! Scoundrels.
Jan 01, 2011 | Polaris 3900 Sport Pool Cleaner ()
My chain sounds like it keeps slipping
It is not slipping unless your sprockets are SHOT.
There should be about 3/4 inch play in the center bottom of your chain when the bike has a normal load on it (read YOU).
Now then, your clutch could be slipping ... have you adjusted it?
I hope this helps you
a
Oct 12, 2009 | Yamaha G5 Motorcycles
Pacific International Mongoose 26 in. Mens Tactic Logo
74 people viewed this question
Top Pacific International Cycling Experts
Michial Gueffroy
Nathan
dante
Are you a Pacific International Cycling Expert? Answer questions, earn points and help others
