Question about Actron Digital Multimeter Tester
How do I put batteries in a gardner bender circuit alert voltage sensor
On my GDT 3200 you had to pry and force the black padded case off of it. There is no instructions how to put the batteries in, and I nearly broke the meter taking off the case. Just try to force that case off of there. Hand strength combined with frustration and anger will help in that step. Once the black armored case is off, it's self explanatory. There's two screws on the back that come out and the red unit splits in two. Install the batteries and put it back together.
Posted on Dec 09, 2010
Does a GB 504 A have a battery?
The 504A uses two silver oxide 357 button batteries. The black top is just press fit in. Gently pry it off. The batteries install with the positive side down.
Aug 05, 2014 | Gb Electrical Gardner Bender GVD-504A...
How do open the unit to install batteries
It doesn't need batteries. It is operated by the voltage in the circuit you're testing. No indication means no voltage (or at least less than 5 volts) is present.
Mar 18, 2010 | Gardner Bender 6V/12V CIRCUIT TESTER
What kind of batteries do i need
2 "AA"batteries,but watch this model,theres a re call on it right now thru fluke
Mar 14, 2010 | Gb Electrical Gardner Bender GVD-504A...
Can't open to change batteries
Need to grab it tight on both sides at black end by pocket clip, and wiggle slightly and pull out at same time. Pocket clip comes off with it.
Jan 03, 2010 | Gb Electrical Gardner Bender GVD-504A...
Gardner Bender #GVT-392 Solenoid Voltage Tester manual where can i download one at
Google " gardner bender GVT-392 manual".... there is plenty of hits good luck
Dec 31, 2009 | Gardner Bender #GVT-392 Solenoid Voltage...
Irregular function of tester GVD-504A
There are two button cell batteries located in the top of the unit. Try removing the black cap. Some twist off and some pull straight up. Note the polarity of the batteries.
Jan 31, 2009 | Gb Electrical Gardner Bender GVD-504A...
I have 6 outlets that do not work.
I would start by determining if these 6 outlets are on the same circuit. Also I am usually not too confident in the non contact voltage tester you are using. They tend to give false positives if they contact anything or even if you move them fast. I would invest in an inexpensive multimeter whcih will allow you to test actual voltage across the poles and ground and also check for continuity between poles/ground (WITH CIRCUIT OFF ONLY).
Did these outlets previously work properly?
Jan 02, 2009 | Gb Electrical Gardner Bender GVD-504A...
Actron Digital Multimeter Tester Logo
326 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
