Hi i just installed a new sata hard drive to run as a slave drive but it shows it as master in the bios how do i change that
    Problem Solver:
  • 6 Answers
Change the cable order of your sata drives to change the drive letter order to help your machine boot. If the first drive is an EIDE drive then the first SATA drive should be a master drive.
Posted on Sep 14, 2010
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
Desktop Acer M1641: 1 IDE optical drive+ 1 SATA HDD. When SATA disabled,both drives appear in Bios n boot sequence. When SATA enbled, only optical drive in Bios. When both are present (as said before)...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
May 18, 2011 | Computers & Internet
I HAVE MY MASTER 160Gb SATA SEAGATE, I HAVE TO ATTACH A NEW 500Gb SATA SEAGATE ,I'VE GONE TO BIOS SET UP. BUT IT DOESN'T DETECT MY NEW DRIVE.CAN YOU SHOW ME THE WAY TO SLAVE A SATA SEAGATE HARD...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
May 16, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
When i installed hard drive and set the jumper on primary master it dint show up and in bios the txt is showing like that primary master drive 0 (not installed)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Feb 06, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
My WDC WD2500JS hard druive is getting noisy and slow. I am thinking of replaceing it before it dies and at the same time do a clean install of Win7. It is now XP. Can I make this drive a slave until I...
first up
uninstall a few unnecessary programs
second
yes you can make it a slave
you will have to change the setting in BIOS for master/slave aswell as the jumper settings
during the boot up process you will see on the screen for a short time press a certain key to enter set up press that key to enter set up
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
make sure the computers motherboard will support windows 7
wait until you get the new drive before before connecting your hard drives to master/slave
depending on the amount of drives your computer has you might have to change letters on all drives
naming of the hard drive you might be able to change the name opening windows explorer navigate to the drive then right click on the drive then select rename
Dec 15, 2010 | Western Digital 250GB WD RE SATAII...
Weird problem. CPU recognizes the sata, windows will not boot, recycles to start-up over and over. Tried with xp disc to repair, came back as "no hard drive listed. If I changer driver from master to slave...
It is possible that Bios/Cmos battery is not maintaining its charge. You might want to pull the cmos battery & check its voltage with a volt meter. It should retain 3volt DC. If it reads lower than 3v replace the battery. Once replaced you will need to reset all bios settings. If the battery checks out ok than continue.
The soulation to your problem lies within the Bios not your hard disk drive. Set the jumper you moved to slave back to master. Re-connect the SATA data & power connector to the motherboard. Boot up your PC & start pressing the Delete key on your keyboard every two seconds untill the Bios menu opends. (See page 2-14 section 2.3) in your manual.
You can not use your mouse while in the bios. Read page 2-12, section 2.2.1). This will explain how to move about while in the bios. Once the Bios opends you will be at the main menu. If your SATA drive is correctly connected you will see its model number listed there.
If you have two SATA drives connected you should see both. Take note of which is the master SATA1 drive. All SATA drives run as master drives. While in the Bios, SATA drives are shown from top to bottom. First /top drive will be the master drive. Next drive down is considered as slave.
Than open (OnChip SATA controller). Set this to [Native Mode] or to [SATA]. See page 2-16, section 2.3.5
Than open Boot. See page 2-30, section 2.6, Open Boot Device Priority section 2.6.1 Here is where you need to set the boot order.
(The boot order is not set correctly & this is why windows does not see your hard disk drive & showed the message "No hard drive listed").
If you have a floppy disk drive connected to the system set it as,
[1st Boot device]
Change 2nd Boot Device to [CD-ROM]
If you have two CD/DVD-ROM drives in your system make sure you set the Master CD/DVD-ROM here & not the slave CD/DVD-ROM drive.
3rd Boot Device should be the primary [SATA1 drive], connected to SATA1 port on the motherboard. See page 2-30 section 2.6.2
The drive with windows installed shoud be listed as 1st.
Save your changes & exit the bios. Your system will auto re-start.
If you had a working operating system on the drive it should load.
If you need the motherboard manual or drivers you can download them from Asus web site link below;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
Cheers!
If you are still having troubles, post your question here.
Mike
Sep 24, 2009 | ASUS P5S800-VM Motherboard
Pls. help me with my motherboard
Hi iCe_sPeRm, all SATA drives are seen as all masters. While in the bios you'll want to connect the SATA with windows on it to the SATA 1 port on the board. So back in the bios you should see the 80GB drive listed first. The 320GB drive should be on the 2nd SATA port & listed second in the bios under the 80BG drive.
The most important thing to do in the bios is make sure you're 80BG drive is the only drive listed in the boot order.
Once windows has loaded you may need to change drive letters using MS windows diskmgmt.msc. To load disk manager in windows click the start button, click run & type in the run window diskmgmt.msc & click ok. You can change the order that windows see's the drives. You can also rename the drives. EX: Rename C:\ as Master_Drv or Master_80. Than rename the 320GB drive as Slave_320 ECT. This way you'll know which is what.
Foxconn's web site for the 865G7MF-SH MB.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000204
Good Luck!
Mike
Jul 06, 2008 | Foxconn 865G7MF-SH Motherboard
Boot difficulties Seagat Baracuda 7200, 300 GB
Could have something to do with the IDE being set to master.. It has been known that sometimes the SATA drive will take over as the master.. Try changing the IDE drive to cable select, and see if that helps.. If not, change the SATA to slave.
If that doesn't work, post your motherboard model# along with your bios name/version.. and we'll go from there.
As a side note: When they are connected the way they are now, does the bios show both drives?
Mar 28, 2008 | Seagate Barracuda 7200.8 300 GB Hard Drive
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
