Question about Ovens
Old wolf oven .What is the difference in a flat ignitor (#sgr-403) and a round one (#gr-403)
  • threecatstra Sep 14, 2010
    yes but will they work the same and why does it speicfy one or the other
  • Ovens Master
  • 43,501 Answers
The flat is just that, flat and about 1/8" thick.....and the round one is a round spiral....
heatman101
Posted on Sep 14, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 14, 2010
    They are not interchangeable....the piece that holds the ignitor is designed to hold the exact one in the optimum postion to light the burner effectively and efficiently...
    heatman101
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
Bake oven is not igniting. I had replaced the ignoter last year, Now I tested the igniter and it has low resistance so I went to test if it is getting voltage when the oven os set to bake. I saw something...
you have to read it out with a clamp on amp meter,clamp onto one of the ignitor wires and read it out,flat ignitor should read 3.2 amps,round ignitor is 2.5 amps.is the ignitor glowing or not ?
Jan 23, 2011 | Ovens
I have a GE Gave oven. THe top burnes work and the broiler works but when I set the oven to BAKE, nothing happens. THe digital display says it is pre-heating, but it doesnt get hot??
you have a bad ignitor,take out the racks and remove the floor of the oven,you'll see the round ignitor with two 1/4 inch screws holding it on,you can remove the burner tube that the ignitor is connected to with the ignitor on it or you can remove the screws,cut the wires close to the old ignitor and remove it,screw on the new ignitor,leave around6 or 8 inches of wire on the new ignitor,cut back the old wires so you can wire nut the wires together,start the oven and the ignitor should ignite the flame in like 20 to 40 seconds.it doesn't matter what wires you connect,you don't have to worry about if the left wire coming out of the ignitor connects to the same wire the old one connected to,just as long as the wire nuts are tight on the 2 connecting wires you'll be fine.the part number is WB13K21 and the ignitor is around 80 bucks.you can kill the power to the oven but no power is going to the ignitor if the bake isn't on so as long as you don't touch anything else you'll be fine,let me know how you make out
Nov 15, 2010 | GE 30 In Freestanding Gas Range ...
I have a kitchenaid Superba convection oven. I be something else?
it sounds exactly like an ignitor, if u want the original ka part u will pay more,, you could use a 12400035 ignitor, or a sgr403, depends if its round or flat, go to repairclinic.com and enter those part numbers in to see pictures of those, or look up a ka ignitor and compare prices. hope this helps let me know whut u think
Feb 12, 2010 | KitchenAid Ovens
I replaced the WBX20154 glowbar for my oven as
The model number on a built in oven is usually found on the oven frame, just behind the oven door. (should be a metal tag, or silver sticker) It is NOT LIKELY that the oven valve is bad. (although if you have a self clean model, they would have seperate valves for bake and broil)
When the oven is turned on, there should be 120 volts across the ignitor. You can test the igniter by putting one wire into the left side and one into the right side of a standard recepticle, but you have to be careful with bare wires and the ignitor gets hot very quickly, and stays hot for awhile, so if you try it, be very careful. I'm assuming that your original ignitor was a round one also (not a flat one). It is very important to use the same type as the original.
I suspect you have a poor electical connection. Make sure wires are stripped back about 1/2 inch, then make sure the ceramic wire nuts are tight when installed.
Nov 05, 2009 | GE Profile JTP18 Electric Single Oven
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
The ignitor in our oven is no longer being made the replacement is a robertshaw 41-208 how do i put a square peg in a round hole
There should be a bracket with the new ignitor. There are also universal ignitors of the same type as the old one that can be made to work.
Eric
Sep 14, 2009 | Ovens
Hello. I have an old Roper oven, model no.
The ignitor draws amperage thru gas valve which opens the bimetal valve to release the gas.Round ignitor 2.75 amps. Rect. 3.5 amps.Bottom line if burner dont fire within 60 seconds of turning orange you have a weak/bad ignitor.Hope this helps.Please rate my response :)
Jun 20, 2009 | Ovens
Kenmore Gas Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Feb 05, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
112 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
