Question about Home
When I flush my toilet,and it starts to fill it whistles
  • 43,501 Answers
There is dirt in the fill valve....the water squirting by makes the noise...
heatman101
Posted on Sep 14, 2010
Toilet stools whistle after flushing
This could be caused by the sound of water jetting into the water tank. Just open the tap to the water tank slightly more until the whistling stops. The flusher valve in the tank may be leaking, causing the water jet to open again and the whistling noise.
Apr 26, 2016 | Home
How do I stop a 2 second whistle when toilet is flushed?
change the auto fill valve inside the tank, if thts not it go to a longer feed line.
Sep 29, 2014 | Fluidmaster Plumbing
Kohler toilet problems
The fill tubing may be kinked or installed incorrectly. The fill valve itself may be the source of the whistle due to water pressure.
Jul 15, 2014 | Home
Toilet whistles when flushed
That's probably because it doesn't know the words. Just kidding.
Whistling sounds usually indicate some type of restriction in the water supply. It may be the stop valve is not open all the way. Dirt or scale in the fill valve or lime buildup can also cause a whistling noise. check for these issues. and clean or replace parts as necessary.
Hope this helps.
Bob
Jul 11, 2014 | Home
Handle is sticking in one toilet the other toilet makes a loud whisteling noise after flusing
The handle is probably worn out on the first toilet. The whistling on the other toilet is probably from a restriction in the fill valve, if you can live with whistling, it's not really a problem. If not, I recommend trying a different type of valve.
Aug 09, 2011 | Toto Home
When the toilet is flushed there is a whistling sound straight after until the cistern fills up again
The fill valve has dirt in it and the water is squeaking by literally...making the noise....
Either clean the fill valve if it is one that is cleanable or change the valve...
I like to use the Fluidmaster 400A valve it is cleanable and easy to install...
heatman101
Jan 05, 2011 | Home
My Kohler toilet is about 5 years old and is making this awful whistling sound after being flushed. What part needs to be replaced so I can make it quiet again!?
The valve that fills the toilet is making that sound... it is filling up with dirt and the water is struggling to get through the smaller hole...
heatman101
Sep 03, 2010 | Home
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Home Logo
220 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
