Question about ATI RADEON HD 2400 PRO Graphic Card
After updating drivers it will no longer allow my monitor to go to 1600 x 1200 res, but if I uninstall the drivers it will, the only problem with this is without the drivers I cant play the games I want. What causes this and how do I fix it
HOW DO I FIX MY SCREEN RESOLUTION FROM CHANGING FROM 1280X1024 TO 640X480
JFrank,
Your monitor needs to be a high resolution monitor which supports 1280X1024. If is not then this is why your monitor keeps going back to 640x480. If it is a hi res monitor then you may need to update your drivers. If it is a Windows machines simply click the task bar>>control panel>>enter "Windows Update" in search box then click it and your drivers will be updated
Steve
Feb 21, 2015 | Computers & Internet
Some games need 1440x900 resolution to play but when i go to the display settings to change it, its not there just 1360x768, 1600x1200 and lower ones. I need help????
Hi there. If you're able to get 1600x1200 on the monitor, that should suffice--anything equaling or larger than the game's required res is ok...the picture will have a little bit of border on the edges because of the higher resolution but shouldn't be a hinderance at all. Remember this...the higher the resolution, the harder the graphics card has to work to maintain proper movement of the images in the game. Use the exact res if possible. However a close, higher res is fine, too.---Rick
Oct 03, 2009 | HP Compaq WF1907 Monitor
Monitor display wont go higher than 1280 x 720
if your system installed the correct driver to the new monitor or used a dafault driver to run it, this is what you want your system to do to run your old monitor. un install the driver from your system and remove the drivers to a temp folder. reinstall monitor to use a default driver to check it.
if you have the original install disk use that driver instead.
I'm not a advocate of automatic windows updates. if it works fine leave it be.
AndystUK
Aug 30, 2009 | ViewSonic VX2235WM Monitor
My son inadvertantly caused Windows XP to crash; after reloading from the original 2004 disks my system no longer will recognize my E172FPb monitor; no matter how many times I remove and reload the driver...
Hi There: It sounds to me like it's your video card. Look for the drivers for it. This will usually happen if it is an after market card or the drivers are not on the drivers disk. If you have a disk for it fine. If not go to your device manager and see if it can find drivers for it. The fact the monitor is giving you lo res tells me it is working. It's just getting a lo res from the video card. I hope this helps, Jeff.
Jun 21, 2009 | Dell E153FP 15" LCD Monitor
My samsung syncmaster 2233sw shows multiple displayes when i take it to its max res. i use win xp sp2 and have nvidia 8600gt gfx card. the monitor works well on lower res but only shows this problem when i...
Typically this is a driver issue on the host (PC) side. DVI or VGA connection? Update the video driver. Some video drivers (especially older laptops) can't correctly send that resolution.
Jun 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
External Monitor (TV) causes HP nx9420 to reset screen display
can't.....the res for the tv supported is too low.
Apr 25, 2009 | HP Compaq nx9420 Notebook
I purchased samaung 20' monitor and i cant set res 1680x1050 on vista
Check your monitor documentation whether it supports said resolution. May be you have to search for updated display drivers.
Jul 13, 2008 | Computers & Internet
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
My monitor is not allowing me to display a resolution
If you have the origional CD that came with the monitor, use that to re-install the drivers for the monitor back onto the pc. Then go to viewsonic and look for updates. Do a "system restore" and put the system back to the condition prior to doing all of this. I will re store your files to what they were but "system restore" will not roll back "windows updates". This will tell you if it is something you did or windows did.
Aug 16, 2007 | ViewSonic VA1703wb Monitor
ATI RADEON HD 2400 PRO Graphic Card Logo
78 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
