Question about Garmin Forerunner 405 010-00658-20
I have a 405 that has locked up after recharging. It shows a locked time and will not respond to buttons or bezal
  • 831 Answers
Thanks for contacting FixYa.
This is a problem that you will have to contact Garmin on.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=Forerunner 405
Best regards. Jewel
Posted on Sep 14, 2010
  • 2 more comments
  • GSAM123 Oct 02, 2010
    I had similar problem and contacted Garmin's online support. They responded with the following suggestion; "Thank you for contacting Garmin International. I will be glad to help you with this. It appears your Forerunner 405 series may be locked up. To get the device back into working conditions you will want to perform a soft reset on the device. To perform a soft rest on the device you will want to press and hold both silver buttons for a total of 15 seconds or until the unit turns off. At this time release the buttons and within 5 to 10 seconds the unit should power back on. Please note that you may need to do this while the unit is on the charger. Before I received the reply, I was able to exchange the watch for a new one so I don't know if this fix will work - Good Luck.
  • Pconti1 Jul 04, 2011
    I had the same problem - locked up after a full recharge. Took the advise below and it worked beautifully. THANK YOU
  • Francis Sep 03, 2012
    Hello, had the same problem. GSAM123 solution fixed it! Thanks a lot, god bless the interweb!!
    Hello, had the same problem. Thanks GSAM123 it is now fixed. God bless the interweb!!
Central locking not working on drivers door rest of doors working if i open pasenger door by inside door opener
renew the drivers door lock or check if the operating solonoid is seperate from lock if so then often a good drop of engine oil down the operating arm often works
Sep 29, 2010 | 1991 Peugeot 405
My Garmin Forerunner 405 is completely locked up.
In regards to the locked up Garmin: Press and hold BOTH side buttons at the same time until the unit goes blank. Once released, it should be reset...... This should not remove any history or settings.
Mar 22, 2010 | Garmin Forerunner 405 010-00658-20
Screen freezes and display faints
Hopefully the usb adapter just confused the battery. Did you use it this time or a regular plug? Its always best to fully discharge a battery and fully recharge it for the next use. They will lose life and malfunction otherwise. Glad you've had some luck, hopefully it will work just fine now.
Jun 02, 2009 | Garmin Forerunner 405 010-00658-20
Pro 97 scanner is locked up, no buttons respond at all. Can't even reset/initialize. Have fresh batteries in. Help!
Removed rechargeable batteries overnight, installed alkaline batteries next day, it works. Rechargeable batteries test good, so I'm not sure what the problem really was.
May 13, 2009 | Radio Shack Radio Communications
405 frozen
I held both buttons in for about 30 seconds, as someone else had suggested. finally the screen went blank and then it came back as normal.
Feb 08, 2009 | Garmin Forerunner 405 Handheld GPS...
I have a garmin Forerunner 405 and the time was locked at 7:25 am.  I held the two side buttons down in an attempt to reset it, and it just cleared the screen completely.  I charged it last night, and the...
Hi
I had a similar problem, the screen lock while trying to turn GPS on. Tried all butttons and bezel operations, left it charging overnight - no joy. Eventually pressed and held both buttons and after about 30 secs (did not time it but was about that) it restarted.
AllanD
Jan 16, 2009 | Garmin Forerunner 405 Handheld GPS...
Peugeot 307 1.6 petrol central locking problem
leave ign off with key out 3mins disconnet battery 5 mins reconnett and press lock/ unlock repeatedly until locks cycle through to re sync try this any probs come back to me
Dec 25, 2008 | 2005 Peugeot 405
Ipod always on hold
My 2 GB nano shows the lock icon no matter how many times I toggle the hold switch on and off and press the Menu/Select buttons. I've recharged and restored it any number of times with no luck. Computer recognizes it when I plug it in but once I unplug it, none of the buttons work. When it's plugged in and fully updated, it shows the languages menu. I'll be eternally grateful to anyone who can offer any assistance!
Dec 23, 2007 | Apple iPod nano
Menu and OSD Problem
Yep. Sounds like one of the buttons is shorting out and causing the icon to pop up. You can try canned air. If your good with tools, See if you can take the bezal(the plastic part around the screen) apart to clean the button contacts.
Jun 14, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Garmin Forerunner 405 010-00658-20 Logo
592 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
