Question about KitchenAid Refrigerators
Our KitchenAid Superba's Inside lights are not coming on at the Dashboard--where all the lights are. Plus, Filter light is "on".
  • 944 Answers
The water filter needs a replacement.For every 6 months you have to replace the water filter.Its a timer to remind you to change the water filter.When the water filters gets
clogged or contaminated with dust particle you need a replacement.
Press the "EJECT" near the filter and take apart.
Twist the filter's cap in a counterclockwise direction and remove it.
Change the new filter and fit it.
In some models you need to run the water for 5 mins and filter light on button and lock button.In some models you need to Filter button 5 times.
If still the problem persist switch off the unit for 1 hours or more so the unit resets.
If the Dashboard light doesnt works you have to check the connections on the main control board for any loose contacts in the wire.Use mullti -meter for testing and do continuity testing on the board .
comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 14, 2010
Lights are all out
Did all the lights quit at the same time? You can check the bulbs in a seperate fixture. in addition to the bulbs there switches operated by the door and a computer board in the circuit. I doubt either all the bulbs or all the door switches would go bad at the same time, but if the circuit in computer board went bad it might prevent them all from working.
Jul 07, 2010 | KitchenAid Superba Architect KSCS25INSS...
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Superba kitchen aide refrig red light for water filter wont go of
You just need to replace the light switch on the filter control panel. I hope this helps you out.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Fridge Filter
the filter islocated behind the toe grille, ordering instructions areprinted on the filter itself, and resetting the light is a matter of holdingin the button for 3-5 secs, its filtering your water and ice
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
The ice maker is not making ice
I assume "light flashing inside@the switch" means the inside light turns on when you open the door, and goes off when you close the door, or depress the switch manually.
Sounds like the fill valve has failed at the bottom back of the refrigerator.
Reply back your findings if that is not it and I will give you more suggestions.
Jan 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba
You indicator light on your fridge is set on a timer. If you never took a single glass of water it would go on after six months or so. It is just an aide to remind you. To replace it, firmly turn counterclockwise about a quarter turn with a little pressure pulling down or out depending on the location of the filter. You need not turn off water. Replace with new one.
Sep 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Mar 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
