Question about Sony SLV-775HF VCR
What model remote works with sony SLV-775HF - Sony SLV-775HF VCR
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Sony SLV-775HF issue (power off, freeze, digital cable related?)
These guys have the owners manual and the service manual for your exact model; http://www.user-manuals.com/advanced_search_result.php?keywords=sony+SLV-775HF+manual&forward=plist&osCsid=a4cf756dbc2b6f254269ca22308687e5 Sorry I haven't been able to locate these for free anywhere, Sony do not have them available online. Here is the link to the Wow cable instructions - i couldn't find much in there but you may see something that helps out, check pages 65-67 to be sure you have everything hooked up right; http://www1.wowway.com/cable/pdf/WOWGuide.pdf Here is the link to the user manual for the explorer 3200; http://www.scientificatlanta.com/products/consumers/new_explorer2200.htm and here for the FAQs; http://www.scientificatlanta.com/products/consumers/FAQs.htm Hope this helps, if you get some more ideas but still no solution, please post back and i can try again :)"
Posted on Jul 03, 2007
  • 403 Answers
SOURCE: Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
hansola
  • 279 Answers
SOURCE: i need the original code for my sony vcr model #
Your universal remote control should have its own list of codes for products that you want to program. Do you not have this list anymore? You should be able to locate it online. I can help you with that. What is the make and model of the remote?
Posted on Nov 13, 2009
Grubhead
  • 5487 Answers
SOURCE: instruction manual for sony slv se730 vcr
Have you tried the Sony Website? They often have free PDF's of them.
Posted on Nov 11, 2011
Jan 28, 2007 | Sony SLV-775HF VCR
Can i my program my sony dvd/vhs slv-d380p with out remote control
You can only do One-Touch Recording without a remote (if you do not need to change the input). Press REC on the unit with a blank cassette in the unit. However, you can buy a replacement remote control from Sony for $20.95 at https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=SLVD380P&sessionId=MEu4cyyCPB_tX52Te6QhWL2 . Remotes.com also has the remote (for more than Sony charges). A universal remote may work but you will need to check if the timer feature is matched by the remote codes.
The manual for the slv-d380p is available from Sony: http://esupport.sony.com/US/perl/model-documents.pl?mdl=SLVD380P .
I hope this helps.
Jul 25, 2011 | Televison & Video
Where can I get a remote control for the Sony VHS SLV 685HS?
You can get a duplicate of the original remote (new or used) here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=SLV-685HF&uuid=12875134515770 for the 685HF. I can not find the SLV 685HS is not a valid model that I can find at either Sony Parts or Remotes.com.
However, a refurbished remote for the SLV685HS is listed at: http://www.replacementremotes.com/SONY/Buy-RMT-V231A-RMTV231A-147555321-Video-Remote-Control.html . (E-bay also lists a few remotes for th SLV685HS; these listings may or may not still be valid.)
I hope this helps.
Oct 19, 2010 | Sony SLV-685HF VHS VCR
Just purchased a used sony slv-d300p without a remote. Where can I purchase one
eBay.com offers many Remote Controls. Input the brand and model of your Sony Combo and your search will automatically produce separate Remote Controls along with separate listings for the Combo devices. These new or used Remotes typically range in price from $10-$20.
Good luck.
Oct 02, 2010 | Sony SLV-D300P DVD Player/VCR
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
CAN NOT INSERT A TAPE WHEN POWER IS TURNED ON
Sony VCRs have shown these error codes for years whenever a problem occurs but it really does not help much to know what the code means. Even if you knew the code meaning you still would not know exactly what to fix in the VCR. Suffice it to say the VCR probably needs repair.
Go to https://eservice.sony.com/webrma/web/index.do
and enter your zipcode to locate a SONY repair facility.
Apr 28, 2010 | Sony SLV-775HF VCR
I have lost the remote for the SLV-SE740 model VCR. What is the model of the Sony original remote that I need ?
I've purchased the manual which should specify the associated remote.
Thanks,
Adrian
Jan 25, 2010 | Sony SLV-SE740 VHS VCR
Remote control gives wrong signals
You should goggle the model number and check if they have supplied you with the correct remote control.
Nov 04, 2017 | Sony SLV-ED40 VHS VCR
Sony SLV-775HF
Hi, Sounds like a mechanical problem in the tape path which can be anything from the pinch roller, take up spool, foreign object (such as splicing tape lodged somewhere), brake or others. An indicator would be stretch tape. One way to check if the tape is being stretch is to rewind partially one of the tapes you have tried, eject it and open the flap/cover of the cartridge. There is a stub on one of the side of the tape that you have to push to open it and see the actual tape. Stretching if any would be clearly visible. Am afraid that you would need the services of a qualified technician for the actual repair not unless you are familiar with video tape mechanism. On the video head, offhand, I doubt if it needs replacement.Of course an on site technician would be in a far better position to diagnose it for you. Hope this be of some help and pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | Sony SLV-775HF VCR
Televison & Video Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
