Question about Splendide 2000S Vented Washer/Dryer
Where the heck is the lint filter - Splendide 2000S Vented Washer/Dryer
    Problem Solver:
  • 19 Answers
In the back where the dryer vent hose connects to the unit. It's the pastic piece between the metal and where the hose is attached on the upper left corner (if you're facing the unit) and you pull it up to remove it and clean off the lint. It is suprisingly small.
Posted on Oct 24, 2010
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
I have lots of lint that gets trapped under and all around lint filter and it is very hard to get out - why is it not being contained? GE Dryer DBVH512EFOWW front load.
Hi rstebly...
Sometimes the problem is with the lint filter itself...
If you use "dryer sheets" they can plug up the holes in the lint filter with a kind of waxy substance and that will impair the air getting thru the filter causing the lint and air to find another way out, not thru the filter but thru the machine.
I would suggest you take the filter out and wash/scrub, lightly it in hot soapy water, let dry, then reinstall the filter.
You should also check the blower /blower tube and the inside of your dryer for lint buildup also, as lint buildup can cause dryer fires.
Hopefully this will solve your problem
Free Answer...Please rate me
Apr 28, 2011 | GE DBVH512EFWW Dryer
Dryer "clean lint filter" message
Hello. Begin by unplugging the plug on the dryer. Then pull out the filter and thoroughly examine the space that the filter slides into looking for any lint. Remove any lint that you find. Put the filter back and lastly plug the dryer back in.
These steps should solve the problem. If not, then the lint sensor has gone bad and should be replaced. If you wish to do that yourself you can go to searspartsdirect.com. Enter the model number of the dryer and then you will see the parts diagrams allowing you to locate that lint sensor, and even order a new one. Joe
Thanks for choosing Fixya!
Mar 07, 2011 | Dryers
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
Looking for the lint filter
you did not give me a mod # of your washer .... so i will go through the history of the lint filter 1955-1964 the lint filter was on the right side under the lid , twist knob and pull screen out 1965-1986 lint filter was self cleaning mounted under the washer 1987 -today there is no lint filters any more ..... lint filters where used when people hung the clothes out on the line .... today most people use a DRYER that has the lint filter in it .... i hope this helpes ....... if you are going to rate this please rate this 3 or 4 stars , that will keep me in the paid answer department . thanks
Apr 01, 2009 | Washing Machines
My washer has stopped working and flashes F 02?
Drain out water thru front panel, will find hose there. Press & hold 'end of cycle' for 3 seconds, then try the door after 2 minutes or until you hear a click. Power shd be on.
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. Power off the wall socket. You have to remove the bottom front panel, 3 screws underneath. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lint filter not blocking lint
Make sure it isn't bent or has any holes in it and is sealing around the edges. If not, replace it .
Mar 19, 2009 | GE DCVH515EFWW Electric Dryer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
Splendide 2000S Vented Washer/Dryer Logo
336 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
JP Services
JP Services
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
