Question about GE Profile Spectra JGBP90 Gas Kitchen Range
How do you turn off the self cleaning oven when door is locked on the GE Spectra XL44
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 14, 2010
heatman101
  • 43501 Answers
SOURCE: ge xl44 self cleaning gas oven willnot come on
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Oct 03, 2010
Master_Tech
  • 770 Answers
SOURCE: ge spectra xl44
unit needs to cool down to release the latch assby
Posted on Jan 26, 2008
huuum
  • 750 Answers
SOURCE: ge oven profile spectra xl44
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
Why do you need to do this?
If the door lock is stuck in closed position and preventing you from using the range?
You may free this by following this procedure.
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects most problems!.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the lock switch itself is bad and if you think you can bypass it then you may as well change it. Same labor!!.
Let me know how it works out.
Huuum
Please remember to leave a rating.
Posted on Sep 25, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
  • 52 Answers
SOURCE: GE Spectra XL44 burned cabinets during self cleaning
the gasket or seal is likely gone ...replace
Posted on Jul 25, 2009
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
heatman101
Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 self cleaning gas oven willnot come on
heatman101
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 after self clean cycle the door won't open and the display says "locked door" flashing.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Sep 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oct 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Self clean oven won't come on after I cleaned it
It turned out that the lever for locking the oven wasn't pushed all the way after I cleaned it. We just keep playing with it and finally the oven came on.
Feb 10, 2008 | GE DBSR453EBWW Electric Dryer
Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Jan 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44
Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
600 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
