Question about Jacuzzi Bath Fontana G932 959 White Whirlpool Bath
Just installed the Jacuzzi Fontana tub with inline heater. The light on the heater came on then shut off. I have added cold water to the tub but the light on the heater has not turned back on. What's up?
2 Suggested Answers
Bati99
  • 88 Answers
SOURCE: I need the installation instructions for a Jacuzzi Fontana Whirlp
go to jacuzzi.com - downloads
Posted on Apr 16, 2009
Where is the hot-water output shut-off valve on a Bradford-White Hydro-Jet 80 ga. water heater ...and which way do you turn it?
Typically water heaters do not have a shut off valve for the out put water line, only on the cold water line above the water heater and they have a boiler drain to drain the tank. The input shut off valve can be of two types. The usual hose bib style like you would have on the outside of your home for your garden hose (remember lefty loosie, righty tighty) or you could have a gate valve of which if the handle is inline with the pipe the valve is open. You will either have to push it up or down depending on how it was installed, 90 degrees to shut it off.
I hope this is of some help.
Nov 04, 2016 | Water Water Heaters
Jacuzzi z112
What is the problem you afe having with your Jacuzzi Water Heater?
Is this a Jacuzzi Hot Tub?-- Do you have some indicator lights on?-- what color are the lights?--
Is the Circulating pump running water thru the heater element?
Tell me more!-- Let's walk thru the system, and figure it out-- Mack B
Oct 13, 2013 | Water Heaters
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
Jun 05, 2013 | Maax Crescendo - 100085-000 Bathtub
Atwood water heater electronic ignition
Copy following link for possible troubleshoot resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Might want to call service technician instead of messing with gas appliance.
Or sent to service center.
Install 20 gallon under counter electric water heater and connect to 120Volt... 1500 watt element will heat water pretty quickly. To have more hot available, turn up water heater thermostat, then that will give 2 showers because more cold will be added to very hot water, thereby stretching amount of available hot..
Add a comment as needed
Jun 02, 2013 | Water Heaters
I installed a dhc tankless heater, but when I open only the hot water everything is ok, but when I open the cold water at the same time the heater turns off.
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Stiebel Eltron DHC-E 8 Tankless Electric...
Grounding wire# 8 cooper
The # 8 wire is a bonding wire for the hot tub or jacuzzi. It is to interconnect all the metal parts and equipment associated with the unit, pump, pipes, handrails, and also now there is a bushing that goes in the piping run to bond the water itself .
This wire will be incdentally connected to the electrical ground when it is bonded to the motor body.
Jun 10, 2010 | Jacuzzi RapidHeat Inline Heater S750
I have a new water heater. However, its capacity
You could fill with hot water first then add cold to your temp request.The thing to do would of been to buy the tub with its own heater
May 14, 2010 | Water Heaters
No you cannot safely increase the output of a tankless water heater. The alternatives would be to install a heater in your Jacuzzi or to add a tank type water heater to hold water for the tub and then run the haot water from the tankles into the tank. This way all the tank is doing is holding water for you to use and not heating it. Kinda defeats one of the purposes of having a tankles though.
Only other option would be to exchange the tankles for a higher ouput one. Also an exspensive option.
heatman101
Mar 26, 2010 | Whirlpool Water Heaters
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Jacuzzi Bath Fontana G932 959 White Whirlpool Bath Logo
46 people viewed this question
Top Jacuzzi Water Heaters Experts
Nicola Conroy
ray gallant
Are you a Jacuzzi Water Heater Expert? Answer questions, earn points and help others
