Take off the valve cover check make sure nothing broken get a tool from auto zone measure the gap between the lifter and the valve sorry cant think what tool is called theyll know and they tell how much gap should be measure each valve use a small flathead to tighten bolt on top lifter to proper spec this should fix it replace valve cover gasket while apart cause after get it back togethor old one probably leak hope this helps
