Question about Coleman Powermate Premium Plus 6250W Portable Generator
Looking for replacement parts for my Yokohama 8500e portable generator. I need a fuel shut off valve and a voltage regulator.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
You can buy parts from Generator Guru.
http://www.generatorguru.com/yk8500e/?sort=featured
Posted on Sep 25, 2015
3 Suggested Answers
  • 83 Answers
SOURCE: Honda EMS 4500 Generator - High Voltage Problem
As far as I can tell on the wiring diagram for this generator there is no voltage regulator unless it's incorporated with the auto throttle unit.
To lower the voltage you need to lower the speed of the generator engine. To do this there should be a screw on top of the engine under the tank when your facing the recoil. This screw presses on a arm that controls your governor. Turning it in (righty tighty) will increase rpms, turning it out will lower them. You should see the voltage change on the voltmeter.
Posted on Mar 31, 2009
  • 57 Answers
SOURCE: I have a honda generator em2500x voltage problem
My E2500 did this. Turned out to be dirt in the brush holders causing the
brushes to have less pressure in the slip rings. Stopping and restarting
joggled the brushes to make better contact until they wore down again.
Pull your brushes and make sure they slide easily in your holders. Also
you may need to replace them if they are worn too much or clean the
slip rings. Good luck. Doing your own repairs is fun.... especially when
they work.
Posted on Jul 29, 2009
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Fuel in oil reservoir and gushes out when cap is removed.
    possibility that the float needle is not shutting off and the fuel is leaking past the valves into the cylinder past the rings into the sump
    drain the sump, refill to the correct level and turn off the fuel tap under the tank
    if the level doesn't change after a period of time then overhaul the carby and turn the tap off after each use
    Sep 06, 2015 | Cars & Trucks
    Fuel mixing with oil and filling oil tank and cylinder.
    the ethanol gas has a way of ruining the rubber tip on the needle valve (in carburetor). When the rubber tip on that valve or the rubber on the Seat go bad, gas can constantly want to fill the carburetor bowl. so much so that it runs into the engine cylinder and past the Rings to the crankcase.
    You can replace the needle valve and seat in the carb which is best OR you can put an in-line shutoff on the fuel line and turn it off when you are not using the generator.
    Ethanol gas.. very very bad for carburetors.
    Sep 05, 2015 | Garden
    Bought new. No problems until two weeks ago. Now has 252 HRS. Starts all the time, runs 10 seconds then shuts down. I have removed wire an oil pressure switch. no help. Found connector off on switch p
    It shuts down because it's not making power. You are probably getting a failure to start error code. If it doesn't make power it doesn
    t know its running. Rotor has lost residual magnetism to start the voltage regulator. Replace the voltage regulator. The new one is designed to overcome this.
    Dec 10, 2014 | Briggs & Stratton Briggs Stratton 7 kW...
    Looking for parts for my yokohuma yk8500E generator, plug, air fliter
    Same. I have one to repair, Most of the wiring for the ignition system is missing, andI cannot find a wiring diagram or workshop manual ANYWHERE.
    Nov 16, 2012 | Coleman Powermate Premium Plus 6250W...
    My heater keeps going out. full propane bottle , but it keeps shutting itsef off i have tried it both with 2 full cylinders , and a 20# bottle ,
    look in back of the heater where the fuel nozzle goes. you will see a plate with a bunch of holes, the ignitor and the fan. also there is a little button with two wires on it. these wires connect to two spade terminals on the millivolt generator. its sensing bulb is near to the fuel nozzle. the other end with the gland nut goes into the main valve body. when the heater is on, the flame hits the millivolt generator and makes a very small DC voltage which goes through the little disk [an overload] then to the main valve solenoid. if the millivolt generator is good then there is a voltage at the main valve solenoid and it keeps the valve open. in your case it seems 1) the overload is open 2) the generator needs to be replaced. please go to desatech site and order a new generator.
    Oct 24, 2009 | Mr. Heater Mr Heater Portable Buddy...
    Coleman Powermate Premium Plus 6250W Portable Generator Logo
    1,148 people viewed this question
    Top Coleman Electrical Supplies Experts
    John Trevino
    Shawn DuRee
    Phil Walker
    Phil Walker
    Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
