Question about Dell 5100cn Laser Printer
Mi impresora esta prsentado un error 016-317 Resetear impresora, pero la misma tiene todos los botones disabled. que debo hacer en este caso??? saludos
  • 2072 Answers
SOURCE: 016-317
I am sorry, I recently left that job and no longer have the documentation to answer most questions concerning xerox product fault codes.
My apologies, I just no longer have that information.
Posted on May 31, 2008
  • 59 Answers
SOURCE: mi webcam tiene un password, pero no recuerdo
English Please....
Posted on Nov 14, 2009
  • 27 Answers
SOURCE: en el panel aparece parpadenado el led de
no oblo espanol?
Posted on Nov 19, 2009
nblady
  • 206 Answers
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Posted on Feb 24, 2010
Joed911
  • 4338 Answers
SOURCE: el problema que tengo es
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Posted on Nov 30, 2010
Hp officejet j3600 error del cartucho
Saludos
Mi nombre es Jose, es un placer intentar ayudarle para ello le recomiendo que limpies los conectores y mires bien cual es el cartucho que tiene problemas, de todas maneras puedes mirar este post.
Como solucionar error en cartucho impresoras hp
Oct 31, 2012 | Office Equipment & Supplies
Como puedo programar un control de remplaso para tv2?
Hola mi nombre es Kimberly Ecobar con DISH Network. Tengo enetendido que necesita programar su control de remplaso con su T.V 2. Para programar el control tiene que hacerlo desde la T.V numero1, cuando usted se encuentre alli tiene que entrar a la pantalla System Info. Esto se puede hacer oprimiendo el boton de Menu 2 veces en el control #1 o tambien oprimiendo el boton System Info enfrente del recibidor, Una vez se encuentre dentro de la pantalla System Info hacia la parte de abajo tendra algo que dice Primary Remote Address y Secondary Remote Address a la par de esto una cajita blanca que contiene un numero adentro. El procedimeinto a programar el control es el siguiente: oprima el boton de SAT localisado en la parte de arriba hasta que los demas botones se iluminen en rojo una vez esto suceda ingrese un numero ente 1-15 (pero diferente al que se encuentra dentro de la caja blanca a la par de Secondary Remote address) y despues el signo de numero (#) seguido por el boton de record. El numero dentro de la caja blanca para secondary remote address debe de cambiar al numero que usted elijio si esto no secede asi intente de nuevo el procedimiento esta vez oprimiendo el boton de record 3 veces. En este link puede encontrar todo el procedimiento y mas informacion en como programar su control http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene mas preguntas o necesita ayuda por favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda.
Feb 12, 2011 | DISH Network IR Remote Control
Tengo un control nuevo de dish y no puedo cambiar los canale no se como programarlo
Mi nombre es Kimberly Escobar, representante de servicio al cliente con DISH Network. Siento mucho que este teniendo un problema programando su control nuevo con el recibidor. El procediminto es el siguiente: primeramente en la television donde esta el recibidor tiene que ingresar la pantalla llamada "System Info" esto lo puede hacer oprimiendo el boton de System Info enfrente del recibidor o puede sacar la tarjeta que se encuentra adrento del recibidor, en unos segundos sale la pantalla System Info. En la pantalla de System Info donde dice "remote address" va a ver una cajita blanca que adrento contiene un numero. Usted va a oprimir el boton de SAT hasta que los demas botones se iluminen rojos, una vez que se iluminen ingrese un numero entre 1-15 (pero diferente al que se encuentra adentro de la cajita blanca) seguido por el signo de numero (#) y oprima el boton de Record 1 vez, el boton SAT debe de iluminarce 3 veces. Trate de usar su control deberia funcionar. Espero esto le ayude tambien puede referirse a este link http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara todo el procedimiento. Si necesita mas ayuda o tiene preguntas por favor contactenos directamente al 1800-333-DISH gracias!
Nov 21, 2010 | DISH Network IR Remote Control
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Mstr2kx
Yenny salu2 desde Mexico...
querida amiga lo unico que tienes que hacer es presionar el boton de play por unos segundos asegurandote que el boton de Lock que se encuantra en la parte de atras no este en rojo, eso seria todo, si esto no funciona hay un pequeño orificio en el PD-6070 MP3 player que dice Reset presiona hay y repite la primera instruccion. Yo se que funciona lo hice con el mio. Espero que te ayude esta informacion...
Mar 12, 2008 | MyMusix PD-6070 MP3 Player
Dell 5100cn Laser Printer Logo
56 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
