Question about Sharp AQUOS Blu-ray Disc Player
I cant connect it to netflix it says no internet connection found.help
My netflix is saying cant connect to it why?
First check your internet connection. If that is not an issue, try to connect to Netflix on another device.
If none of this works and netflix displays an 'error code' , simply paste this into google like so -
" Netflix Error Code 'your error code here' "
Oct 29, 2017 | Computers & Internet
Why can't I connect to Netflix?
my wifes Netflix takes awhile sometimes when
net traffic is peaked.
this morning we could not open any site but 2 hours later it came back. techies musta been werking on the lines
Aug 28, 2017 | Internet Computers & Internet
Why wont Netflix connect
Here's how to fix many Netflix streaming problems. Restart your iPhone, Smart TV, Game Console or whatever device you are using to stream Netflix. Restart your Router. Unplug your wireless router from power for 60 seconds then plug it back in.25 May 2016
13 Common Netflix Problems & Fixes - GottaBeMobile
www.gottabemobile.com/2016/05/25/common-netflix-problems-fixes/
Nov 20, 2016 | Computers & Internet
I cant connect to netflix
Troubleshooting Network Connection Issues - Netflix
https://help.netflix.com/en/node/85
NetflixIf you are experiencing Internet related streaming issues such as the error "CannotConnect to the Internet," this article will help troubleshoot your home network.
10 Common Netflix Problems & Fixes - GottaBeMobile
Jan 18, 2016 | Computers & Internet
How come I can get Netflix on 1 tv and not the 2nd tv I worked fine until yesterday it stopped on the 2nd tv but other sites work on it
Start by troubleshooting whether your second tv has an appropriate internet connection. I have found that with multiple devices connecting to the same NETFLIX account, often has intermittent connectivity problems attributed to the device connection to the internet.
Oct 27, 2014 | Roku 2 XD Streaming Player 1080p
Cant get oo computor
Test the Internet Connection
Make sure yourcomputor an Internet connection by opening another Internet application or the app store.
  • If you are not able to reach the Internet through your cellular carrier, try a wireless network.
  • If you are not able to reach the Internet through a wireless network, you may having network connection issues
  1. Check the date and time on your computor
    If the date and time of your device is significantly different from the current date and time, you will have a problem playing your video.
    1. Tap the Settings icon on the Home screen.
    2. Tap General.
    3. Tap Date & Time.
    4. Tap Set Date & Time.
      • If the date and time are incorrect, adjust the time until it matches your time zone.
      • Or, tap On/Off toggle to On in the Set Automatically field.
  2. Reinstall the Netflix application
    1. From the main menu, touch and hold the Netflix app on the Home screen until it jiggles.
    2. Tap the X in the top left of the Netflix icon, then tap Delete.
    3. Enter the App Store, search for "Netflix" and select the free Netflix app from Netflix, Inc.
    4. Tap the Install button. You will need to enter your iTunes password to install the app.
    5. Once installed, tap the Netflix icon.
    6. Enter the email and password for your Netflix account and tap Sign In.
  3. Troubleshoot your Internet Connection
Oct 24, 2013 | Netflix
Yes i cant get in to see movies dont know what
The following error messages indicate an interrupted connection to Netflix:Cannot Connect to NetflixCannot reach Netflix.comNetflix is Not AvailableNetflix is UnavailableUnable to Connect to NetflixAndroid Error: Connection FailedMost connection problems that prevent streaming occur on the device itself, or on the home network. In a nutshell, we will have you test the Internet connection on the device, log out and back into Netflix, restart your device, and restart your home network equipment.
Oct 12, 2013 | Netflix
Setting up wii for netflix
Netflix Instant is available for streaming on your Wii gaming console by early spring 2010. If you have a Netflix subscription you can watch movies and episodes easily on your TV through your Wii console. This article will detail the important things you will need to make sure that you can watch Netflix from the Wii.
Difficulty:Easy Instructions Things You'll Need
  • Netflix subscription
  • Nintendo Wii gaming console
  • Broadband internet
    • 1 Check you Netflix subscription. The minimum subscription plan to watch Netflix instantly is the unlimited 1 DVD at a time plan or otherwise the $8.99 plan. This plan allows to watch movies instantly with unlimited monthly hours.
    • 2 Check internet bandwidth on your broadband connection. According to Netflix the minimum bandwidth requirement is 1.5Mbps. Netflix recommends for watching movies instantly a 3.0Mbps connection. Check with your internet service provider to confirm that these download speeds.
    • 3 A wired connection to your Wii console. An ethernet connection to your Wii console would be preferable. Unfortunately the Wii console does not have an ethernet port but a USB port. A USB LAN Adapter can be found at most computer supply merchants or online from Wii or Amazon.com. The ethernet connection is an ethernet wire from your home LAN router connected to your USB LAN adapter. The USB LAN adapter is then connected to the USB port on the Wii console. This connection will be how Netflix provides the movie streaming feed to the Wii.
    • 4 Sign up at the Netflix website for the Streaming Disc. Netflix will send a specially programmed disc to setup the Wii for watching the movies. When the disc arrives Netflix will provide instructions on how to install onto the Wii gaming console.
Read more: How to Setup Netflix for Wii ' eHow.com http://www.ehow.com/how_5893624_setup-netflix-wii.html#ixzz1OybxaAO2
if this help you please rate me sir thank you so much...
Jun 11, 2011 | Nintendo Video Game Consoles & Games
I can't get my Netflix Wii thing to connect to the internet Wirelessly. Can you help or at least give me advise? Thank You!
Sorry to hear your having problems with your wii. You can connect the wii via wifi or wired with an adapter. Check out Nintendo's tutorial for instructions on how to do this:
http://us.wii.com/connect/
You basically goto:
Wii Options at the bottom left corner of your home screen, then Wii Settings, Click the right arrow to goto the next page, Click Internet, Click Connection Settings, Click Connection 1, Click Wireless Connection. Click Search for an Access Point. Click OK to view the found access points. Select the Access point for your wireless internet, enter your encryption key, click Ok and then OK again to save settings, and then OK again to test the connection.
If you have done all these setups make sure your selected network and encryption key are correct. If you have an error code search on that error code online.
If you haven't downloaded the netflix channel yet you have to goto the wii store channel and download that first. Then you can link your netflix channel to your netflix account using the on screen instructions when you first start up the netflix channel.
Apr 29, 2011 | Nintendo Video Game Consoles & Games
Sharp AQUOS Blu-ray Disc Player Logo
498 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
