Question about Dell 5650 Computer Speakers
I have a set of Dell MMS 560 speakers. I just recently moved into an apartment from a house. Immediately upon setting up my computer at the new apartment, my main speaker (the one with the volume knob on it) is now picking up a local radio station, even when the computer itself is powered off. As long as the speaker itself is on, the noise comes through. Sometimes it's very faint with a lot of static, and sometimes it's very loud and clear. The radio tower is at least a couple miles away. The volume knob on the speaker does not affect the volume of the radio station, but if the speaker is all the way off, no sound is heard. I tried clipping a noise filter on the cord and it reduced the noise very slightly. I also plugged the speaker into a surge protector that is supposed to filter out this kind of noise. It didn't help at all. Is there any way to get rid of this noise?
    Top Expert:
  • Dell Master
  • 44,894 Answers
Your Dell speaker is detecting the ground wave from the transmitter. Not much you can do to suppress it, short of moving.
Posted on Mar 12, 2017
SOURCE: limited volume on speakers. Worked well previously.
I've had the same problem with my ADA745 system and have run through the same steps as the guys above to no avail. Today, I found this interesting tidbit on the smartcomputing.com web site, posted in 2005: "Using the volume control on the right-front speaker won't turn off the speaker system, and according to the technician we spoke with, leaving the 5.1 speaker system powered on continuously will damage the transformers in the subwoofer." Here's a link to the original: http://www.smartcomputing.com/editorial/article.asp?article=articles/2005/s1604/38s04/38s04.asp&articleid=25728&guid= Thank you very much Dell and Altec for NOT telling me this when I bought the system.
Posted on Dec 30, 2006
Benimur
  • 6966 Answers
SOURCE: Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Posted on Apr 08, 2007
Jowinson
  • 16 Answers
SOURCE: Dell MMS 5650 speaker Volume control
Since it has been working perfectly, you need you change the control knob, there may be a pershal contact that is preventing it from controlling the volume.
Jowinson
Posted on Jun 20, 2008
Mr Emrys
  • 51 Answers
SOURCE: My AS 500 Sound Bar speakers are crakeling (PArt # 4y463)
Usually, the crackling indicates a connection that's not making a good connection. you can try twisting the plug where it connects to your computer and see if you can get it to make a better connect. Also, you may try cleaning the plug itself. When cleaning contacts with any sort of household alcohol, be aware that it can leave a residue so you'll need to use a clean/dry tissue to dry the plug and remove any residue. -hope that helps.
Posted on Dec 27, 2008
sys_admin
  • 829 Answers
SOURCE: static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
I'M TRYING TO CONNECT MY MMS 321 PHILIPS COMPUTER SPEAKERS TO MY 32 in LG TV CAN YOU HELP ?
Hi Richard,
Connecting the speakers tot he LG Tv is fairly simple.. Connect the audio cable from the speakers to the headphone jack on the TV. The headphone jack will be either on the left or right side of your TV depending upon the model number.
I'm attaching the user manual for the speakers for your reference
Thanks for using Fixya
Proton
Mar 13, 2012 | Philips MMS 321 Computer Speakers
My inbuilt speakers are not working.
take a digital multimeter and check through ohms range if there r show continuting the speaker than u know that your speaker is ok
Apr 12, 2010 | Audio Players & Recorders
Samsung Tocco Lite MMS message sending problem
Steps to correct the MMS delivery time
1. Select Menu
2. Select Messages
3. Select Message settings
4. Select Picture Message
5. Select Sending options
6. Select Delivery
7. Select Immediately
8. Save the settings and retest sending MMS.
Mar 01, 2010 | Samsung Cell Phones
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Touchpad+ sound not working
maybe the built in speaker is set to minimum.
press and hold Fn key + Page up
or
go to system set up (F2 when u see the dell logo)
enable the speaker.
Mar 16, 2009 | Dell Inspiron 8100 Notebook
Both right speakers not working
Try to interchange the connections of left channel and the right channel. If there is sound now in the right channel and no sound in the left channel it means that you have problem in the sound card. Otherwise if the problem remains the same you have a defective speaker on your right speaker system but don't forget to take a second look on your speaker wiring.
Oct 22, 2006 | Dell 5650 Computer Speakers
Dell 5650 Computer Speakers Logo
216 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
