Question about Frigidaire Dryers
FRIDIDAIRE DRYER LEAVES LOT OF MOISTURE AND CLOTHES DO NOT DRY
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 14, 2010
Why dryer shuts off too early on auto
The sensor detects the moisture content of the clothes, If the clothing is packed tightly some of the clothes in the middle of the pile might not dry completely, if the clothes on the outside near the drum have low enough moisture. If you have a position on the control for dryer clothes or a more dry position try using that or use timed dry.
Aug 01, 2014 | Whirlpool Dryers
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
My dryer won't dry
This particular dryer has a blower wheel that is plastic. Over time the wheel gets wobbly and loose. If you hear a rattle that could be the loose blower wheel. This causes the dryer to overheat and take 3 times as long to dry clothes because it trips the limits. To get into the dryer and find out you need to first remove the door. Nice how to video from Angel:
Oct 13, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Cloths take way too long to dry. Heat is working in dryer. Timer works, counts down from 60 min, buttheremo drying timer takes way too long.
You will need to check the dryer venting system for a restriction. If there is a restriciton in the venting system the dryer will get hot but the clothes will stay wet due to the moisture never leaves the dryer. First check the air flow at the vent exit located outside. Verify that there is plenty of airflow. Make sure the vent screen is not plugged. Then remove the screen and visually inspect for excessive lint. Then go inside and check the moisture vent hose behind the dryer. Verify that the vent hose is not kinked or restricted. Then remove the hose and clear out any excessive lint. Then check the vent opening at the back of the dryer for any excessive lint build-up. There is a vent cleaning kit that you can purchase from any home improvement store that you can use to clean out the venting system also. When you are done airflow should be good and clothes should properly dry.
Jan 22, 2010 | Maytag Dryers
Dryer heats up but does not dry clothes completely after 60 minute cycle
try giving them an extra spin in washer I do this all the time extracts a lot more moisture out of your clothes and cuts dryer time as well
Dec 18, 2009 | Whirlpool LEQ9858P Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Takes too long to dry or keeps running when clothes are dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
A lot of moisture in the exhaust line of dryer...
thats easy the moisture from your clothes ,,and the outside air,,where ever you live its a lot of moisture in the air,,now the cold air from outside is coming back in dryer and the hot moist air is trying to get out,,bingo condensation,,in your dryer exhaust vent tube ,,hince all the water,,,,now to fix that ,,we need to dump all the water from vent exhaust tube ,,you may need a new one because it will mostly rot...and check the flap or put a window exhaust kit on the house or window,,to stop air flow from coming back in the dryer ,,and where done..onthejob
Jan 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
