Question about BenQ FP731 17" LCD Monitor
How to open the BENQ G2400W LCD monitor to repair the power button that got pushed into the opening
  • 732 Answers
Even if you watch 10 video clips of LCD monitor disassembly at YOUTUBE, you will not find it very easy to do!! Do not use ANY sharp cutting instruments to "PART" the rear cover from the front bezel. One carless slip and it's a trip to local hospital "ER" to be sewed back together!!! Protect the GLASS lcd panel at ALL COSTS. YOU CRACK-IT, YOU BOUGHT IT, YOU OWN-IT, TOYOTA!!! 12fixlouie
Posted on Sep 14, 2010
BenQ G2400W power save mode works find with DVI but will not go into power save using HDMI cable.
Look on the remote find the button under menu then on the screen find sleep timer or power saber and turn off.
Terry
Jan 31, 2015 | BenQ G2400W Monitor
Lcd benq t705 power button not working
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Nov 24, 2013 | BenQ T705 17" LCD Monitor
Benq Q5C3
Someone would have to open the unit and see if fuse bad or even puffed up caps in the power supply for it.
Dec 06, 2012 | BenQ FP731 17" LCD Monitor
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
BenQ Q24W5 LCD monitor circuit diagram
HI.............
Repairing BenQ 17′ LCD Monitor
I came across a common fault problem in BenQ 17′ LCD Monitor. The problem is have power but no display. Once you has opened the LCD cover, check the pico fuse for open circuit (very common), the push pull transistors C5707 for short circuit and the Buck royer circuit p-channel fet FQU11P06 also for short circuit too. For your information, if you can't get the FQU11p06 you can always use FU9024N as a replacement. Resolder all the high voltage transformer pins and replace the components above and I'm sure you will bring back the life of this BenQ 17′ LCD Monitor.
You may go to this fairchild semiconductor website to download the spec of the FQU11P06 P-channel FET.
http://www.fairchildsemi.com/ds/FQ/FQU11P06.pdf
GOOD LUCK.............
Sep 23, 2011 | Computers & Internet
Repair BenQ Q24W5 monitor
HIIIIIIIII...................
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
Benq g2400w lcd monitor how to get sound working on the monitor only connected thru DVI
If this montor has built in speakers you would also need to connect the audio wire to the computer. It should be a wire with a green jack on both ends, You'll connect it to the audio in jack on the monitor and the green jack on the back of your computer. Hope this helps.
Oct 09, 2009 | BenQ G2400W LCD Monitor
Benq FP731 LCD not start up, only green power lamp
Opening it will not likely solve your problem. Have you tried another monitor on the computer to see if the problem may be with the computer itself?
Mar 04, 2009 | BenQ FP731 - 17" LCD Monitor
No sound
Dear marco1983,
there are no speakers on G2400W, just the plug hole for speakers that routes forward the sound signal from the HDMI signal.
Sep 06, 2008 | BenQ G2400W Monitor
BenQ FP731 17" LCD Monitor Logo
2,360 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
